calling out all ge-t builders!!! NOT gte swappers!!!
oldsking
789
Chapel Hill, NC
Good thread here!
I just scored a GE motor that I'm going to make turbo. Mainly the block and head will be GE but harness, ecu, coils, ignitor, etc will be 7mgte Internals will be 7mgte also like the PISTONS! no high compression.
Is there a way to open that hole up bigger and tap it? That is exactly where I was hoping to use for my return.
agp1183
23
Lansing, MI
I'm also going the na-T route, but a little bit different. I fabbed up a custom twin log style manifold for two TD04L-13T turbos off of a subaru WRX.
I plan on running GE electronics with a turbo CPS and vvti 2jz coil on plug setup, and I will probably end up using maft-pro to tune it.
I really should start a build thread...
