Van, did you do the stock igniter ground? I ran a ten gauge wire for the coil pack ground and made sure the bolting surface was clean as well. It is a thick wire for the ground, but it works.
IBoughtASupra;1634519 said:Van, did you do the stock igniter ground? I ran a ten gauge wire for the coil pack ground and made sure the bolting surface was clean as well. It is a thick wire for the ground, but it works.
djordan97;1634812 said:lookin good kenny
closetnerd;1634839 said:Looks fun. Wish we could hear more motor.![]()
CajunKenny;1634880 said:True. The GoPro has stunning video quality; but, quite lacking in the audio department. I'll record from inside the car and see how it does then.
IBoughtASupra;1636543 said:Kenny, why are you fidiling with your camera and a suction cup and your wife is in bed alone at this hour of the night? :stickpoke
