Kenny, I'm curious as to what your air temps are typically entering the engine (after I/C) .. I'm trying to figure out a few things on the maft and this info would help me a bit.
Thanks!
Thanks!
CajunKenny;1633276 said:This morning when I drove to work, MAT minimum was 55 and max was 75. There was no boosting involved and ambient temp was ~38*.
WOT MAT's are a different deal altogether...
IBoughtASupra;1633309 said:The portion highlighted in red occured beacuse Kenny is an old man. He makes IJ look young.:biglaugh:
IBoughtASupra;1633309 said:He makes IJ look young.:biglaugh:
whitemike;1633332 said:IJ is OLD!
CajunKenny;1633336 said:Is that even possible...?
There aint no more to say... :biglaugh:
IBoughtASupra;1633342 said:I Think IJ And Betty White Would Be A Good Couple. Grumpy Old Man And A Happy Old Lady, Imagine That.
IJ Has To Be Grumpy, Look At His Smiley, It Is Grumpy Too. LOL!
IBoughtASupra;1633397 said:Kenny is a ricer.
IBoughtASupra;1633397 said:I had to go through a million pages of wheel selection by Kenny. :slap:
IBoughtASupra;1633397 said:Good to see how the car looks now though, change your signature picture because the car looks way better now.:eek3dance
Kenny,Thanks Ron.
The Meth kit will go on as soon as I get my missfire taken care of. My first plan of attack there will be the CPS followed by the TPS. I'm tired of getting on the dyno and having problems!![]()
thedave925;1634314 said:Kenny,
Your build looks great.
Van noticed he too is having break-up during load on dyno runs. He looked at the CPS and though its rusted, the air gap and pick-up coils are in spec.
He plans on pulling the CPS today to remove the rust, but cannot proceed without your recommendation on what abrasive to use. Van says Thanks.
Van,
Personally I don't think surface rust would affect the ability for a signal to be generated and read at the CPS, just an aesthetically unsound sight.
A rag saturated with WD-40 would be safe to wipe the rust and not be detrimental to the plastic or wires.
About the triple quote post and my sense of humor, that's all it is, nothing serious but a personal smile
Maybe a cooler spark plug is needed. And I'm sure we've been over the ground strap for the coil packs. Have the wires to both the coil packs and the CPS degraded enough to affect overall voltage?
IJ.'s solution was a bit of advance where spark-blowout occured... the maft-pro can do that in you case Kenny![]()
Kenny,CajunKenny;1634315 said:Van: When I was looking through your build thread, I don't remember what coil packs you're running. My break-up issues have been solved by switching to the MK4 VVTI Coils. I'm also running the NGK BCPR7ES plugs gapped at .028. As far as ignition goes, this combo seems to be working.
