i just hope they make them in hyper flex caus ei have set in my car and umm they make shit hella stiff
Asterix;887975 said:No, they're not cheap, but develop your own and you'll soon find that they're worth it.
Asterix
nosechunks;888226 said:Someone already made their own and with cost of materials and labor to custom make, one off pieces was the same cost or slightly cheaper as the kit that cost manufacturers maybe 150 bucks to make.
Grimsta;888438 said:Indeed, that is how it goes. My bushing maker can make 4 bushings for $80 out of Delcon. Thats a front LCA set, but if you think about it $20 a bushing isn't cheap. $160 gets me the front and rear LCAs done. I can see if he'd produce more if anyones interested. For producing more he'd probably charge labor so expect to see that $160 go to $360 but thats still under $500 and for self lubrication solid Delcon, hells yeah! Then again if you're looking for comfort hells no
Asterix;888426 said:Maybe you should've read the thread I referenced before saying that. I have personally developed my bushing set that is in my car right now. I even posted my labor cost from an inexpensive machine shop. Most shops charge twice this for small quantity prototypes. The setup time kills them.
Labor cost for 22 bushings: 22 x $25 + 22 x $10 = $770. I can scan invoices if you want.
That's work on a lathe, turning these things out from polyurethane tube stock, plus drilling and cutting the stainless steel tubes that go inside.
Add in the material cost of the polyu and steel and it's even more. I've not figured out how much that cost me, but I guestimate it at $150.
I'd love to see actual evidence of someone making their own for $150. I don't believe it since I've been there. Show me invoices, and including labor time. Don't even get me started on how much it cost me to buy each arm from a junkyard, spend hours removing the old bushings, measuring, and drawing. I wouldn't sell you my drawing set for $150. No way. It's called non-recurring engineering, and I cost $50/hour for that. I'm a design engineer for a living and have been for 16 years now, so I know a few things about the process.
Demand? Show me a list of 25,000 people who want these and I'll make sets for $250. Until you come up with a verified list with money, forget it. If 100 people want them, pay $500. That's how it works.
If you think you can do it for $150, do it. Good luck.
Here's another idea: call up Ronnie K or Horsepower Freaks and see how many sets you'd have to buy to get them for $125 each. Buy them and then see how many you can sell.
Asterix
First part: I just said someone (now i know it was you) made the bushings in the kit for themselves (one off custom pieces, no mold or any type of mass producing equipment) for about the same cost as the kit manufacturers sell.Someone already made their own and with cost of materials and labor to custom make, one off pieces was the same cost or slightly cheaper as the kit that cost manufacturers maybe 150 bucks to make.
Asterix;888426 said:Demand? Show me a list of 25,000 people who want these and I'll make sets for $250. Until you come up with a verified list with money, forget it. If 100 people want them, pay $500. That's how it works.
Asterix;888453 said:Google got me nothing on this delcon, but if it's anything like delrin, look at this picture: http://www.mk3ukr-supra.com/Rear arm 01a.jpg
You'll probably be fine using it for the fronts and uppers, but don't use it in the lower rears.
Asterix
Wiisass;889082 said:So there's a spherical bearing in there? If so, then why use delrin at all? Why not just use a metal outer sleeve?
But if it's just a sleeve that goes through the middle of the delrin, you will still have the same problems that I posted above. It's not the up and down movement that the delrin isn't good for, it's any side to side movement that the arm will see while it moves through its path of travel. The arms don't always go just up and down, if they did, then you could use delrin bushings everywhere, but the path of the wheel isn't truly vertical, so you need to account for the rotation of the arms somewhere.
