I have an 89 7mgte with a jdm motor that was put in by the previous owner. The charcoal canister has no hose coming out of the left side running to the bsvs. The other hose from the throttle body is capped off. The thermostat housing doesn't have a spot bsvs at all? After reading some threads I beleive this is normal on a jdm engine as those cars didn't have a charcoal cannister. Should I connect the capped off piece from the throttle body to the charcoal canister or eliminate it all together which is essentially what's happening now.
