Bov
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
Supra5MGTE said:
or you can just recirculate :) problem solved.
:werd:
the recirculation makes the bov sound just like your old bypass valve though since it eliminates the fin inside, but then again... no more running rich :)
shaeff
Kurt is FTMFW x2!!!!
10
Around
re-circulating also helps keep the turbo in spool, which nobody mentioned yet. ;) hey, any little bit helps. if i'm boosting 15+ psi, that's 15psi of air rushing into my turbo between shifts!
-shaeff
Fastway135
149
Mass
Instead of recirculating I just ran both the ssqv and the stock bpv (if that even helps out with the richness).:dunno:
Still makes the chirp.:bigthumb:
mkiii88supra
93
PA
sounds to me like i should recirculate to make the car run the best. but how hard is this to do on a HKS SSQV? i dont want to have to buy something to make it recirculate if i dont have to.
diy guy
86
dallas
rakkasan said:
Sorry, but unless you have another device that meters how much air is released by the BOV (like a SAFR as Tubbie pointed out), the safc can not compensate. I think you're confusing draw thru vs blow thru maf.
what does a safr do differently than a safc? they're both piggybacks that use load, rpm, and tps to modify fuel.
the amount of air that is released is adjusted by the dec air setting...
from the safc manual:
mkiii88supra
93
PA
where can i get the recirculating piece from? is all that happens from not recirculating it is that the car runs a little rich?
