Well, this isn't much of a build thread, I've been too busy putting the car together to keep posting pictures along the way
There's a picture of my old setup, which was a SP-63 on a Trust header on my 87.
I just picked up the black 89. When I picked it up it was 100% original (including paint) minus the tires and oil. 61k on the odometer. The built longblock was swapped out of the 87 into the 89, as it only had ~3,000 miles on it.
My goal with this car was to only modify things that needed to be modified and to try to keep the car as refined as possible. I think I succeeded. All the emissions systems are still in place. The car is quiet, has a RT cat so there's no smell and it has a very streetable powerband. I was even able to place the BOV such that I could use the OEM hose to the accordion hose. Everything on the car works perfectly. With the glove box closed it looks stock on the inside.
The major modifications are:
- Block with JE pistons, stock rods polished/vibratory stress relieved, balanced, etc..
- Greddy 1.5mm HG (results in 8.5:1 CR)
- Ported head
- Boss Jr. 57 Trim turbo/elbow
- RT downpipe and 3" cat
- HKS sport exhaust
- Greddy intercooler kit
- Lexus AFM/550s/AFPR/MKIV fuel pump
- HKS S-AFR/EVC-IV/IPM/FP gauge/Boost gauge/SSQV
- FJO WB
And lots more...
I have a set of Tein RAs, Tein EDFC, S/T sway bars, and nylon bushings in the 87. I haven't decided what I'm going to do suspension wise. Honestly, for the rough roads we have around here, the stock setup has it's advantages at times. I'm thinking I'm going to get rid of the Tein RAs and buy a set of Tein Flexs. Probably going for some sort of big brake kit in the near future too.
I just drove it on the road for the first time yesterday at 0.8 bar, and am quite rich so I have some tuning to do. Off idle throttle response is drastically improved over the VPC setup. That said, it spools very quickly and pulls quite hard. I'll have dyno numbers soon.
- Ported head
- HKS sport exhaust
- FJO WB
And lots more...
