Helllllllllllllloooooooooooooo SUPRA MANIA!!! I AM BACK!
Been working on this car for the last 1 1/2 years on and off. Well mostly off finally got around to working on it again. This is not my car but I have heavy input on what goes on and will be using it as my track car.
Pretty much this car will be bad ass here are a few of the not worthy parts
Engine
-2JZ-GTE Swap
-Brand new bottom end - stock
-Brand new head - was sent to comptech to build
-HKS 272 Cams
-Tial Blow Off Valve
-Titan Motorsports Adjustable Cam Gears
-Titan Motorsports Crank Pulley
-Toyota 97-98 Motor Mounts
-New OEM Starter
-Rewiring 1JZ-GTE Engine Harness -Removing Excessive Useless Wires
-Rewiring Injector Wires & Mounting Resistor Box Inside Car
-Rewiring Jumper Harness
-Wiring Boost Controller Triggered By AEM
-Wiring Electric Fans - Triggered By AEM
-Wiring Fuel Pump - External Fuel Pump Triggered By AEM
-Wiring Speedo Sensor To AIM Dash
-Wiring Reverse Lights
-Toyota Pilot Bearing
Cooling
-Greddy 3 Row Intercooler
-Greddy Radiator Cap
-Flex A Lite 220 Fans
-Koyo Racing Aluminum Radiator
-Samco Racing Silicon Hoses
-Spooling Performance Custom Intercooler piping
Electronics
-AEM V1 Engine Management
-AEM Air Intake Temperature Sensor
-AEM 3 Bar Map Sensor
-AEM Wideband
-AIM Digital Dash
-Apexi Boost Solenoid
-Greddy Boost Gauge
-Greddy Coolant Temp Glauge
-HKS DLI Spark Amplifier
Exhaust
-Modified MK4 TRD Gen 2 Exhaust
-Spooling Performance Custom Downpipe
Exterior
-Custom FX35 HID Retrofit
-Custom Wiring Harness For Bi-Xenon Projectors
-Digital 55 Watt D2S 5000k Kit
-Fixed Fuel Door
Fuel System
-1200cc Fuel Injectors
-8 Aeroquip TFE Racing Teflon Feed Fuel Line
-6 Aeroquip TFE Racing Teflon Return Fuel Line
-Aeroquip Fittings & TFE Racing Teflon Hose Ends
-Aeromotive Fuel Pressure Regulator
-Aeromotive 12335 Fuel Filter E85 & Gas Friendly 40 Microns & Stainless Steel Mesh
-MK4 Twin turbo Supra Denso Fuel Pump Inlined With External Bosch 044 Fuel Pump
-Titan Motor Sports Fuel Rail
Interior
-AIM Digital Dash
-Custom Polished Bracket With AIM Dash Mounted On
-Custom Shift Boot For 6 Speed Shifter
-Relocate AEM Wideband
-Relocate Boost Gauge
-Roll Cage
-Taylor Battery Relocation Kit & Box
Misc
-Polished Intake Manifold, Throttle Body & Misc Brackets
-Polished Intake & Charge Pipes
-Polished Heat Shields (Brake Master & Clutch Master Cylinders)
-Polished Power Steering Reservoir
-Polished Valve Covers
-Polished TRD Oil Cap
-Relocated Fuse Box Back Into Engine Bay For Easy Access To Fuses
-Wire Tucked Most Wires Fuse Box Connector Ground Wires, Resistor Box
Suspension l Brakes l Wheeks
-Tein Coilovers
-JIC Crossmember Underbrace Bar
-JIC Rear Strut Bar
-ARZ 13" Wilwood 6 Piston BBK
-MK4 Rear 2 Pot Calipers W/ Brembo Rotors
-Wheels / Tires:
-HRE Wheels 540R
-19x11.5 +33
-19x9.5 +35 (15mm spacer) +20 now
-255/35/19 Goodyear eagle F1
-295/30/19 Michelin PS2
Turbo
-Boostlogic Exhaust Manifold
-Greddy Wastegate
-Spooling Performance Custom Dump Tube
-Precision Billet 74mm Turbo
Rear Differential
-USDM 3.73 LSD Rear End Rebuilt with New LSD Clutches Shimmed To Be Aggressive
-Carrier Bearings & Races
-Clutch Pack & Shims
-Pinion Bearings & Races
-Pinion Seal
-Stub Axle Side Seals
-Solid Spacer kit
Transmission
-V160 6 Speed Transplant
-Custom Short-end shifter Tripod & Shifter Linkage
-Carbonetics Triple Disc Clutch
-C's Short Shifter
-Custom Driveline Service 3.5" Steel Drive Shaft
-Toyota Shifter Shaft Seal
Here are some pics from over the last year and the last few are recent
This is what the car looked like when we started
Here are some pics from the last few days
How the car looks as of 2-20-11
Engine
-2JZ-GTE Swap
-HKS 272 Cams
-New OEM Starter
Cooling
Electronics
-AEM Wideband
-AIM Digital Dash
-Greddy Boost Gauge
Exhaust
Exterior
-Fixed Fuel Door
Fuel System
Interior
-AIM Digital Dash
-Roll Cage
Misc
-Tein Coilovers
-JIC Rear Strut Bar
-Wheels / Tires:
-HRE Wheels 540R
-19x11.5 +33
Turbo
-Greddy Wastegate
Rear Differential
-Pinion Seal
-Solid Spacer kit
Transmission
-C's Short Shifter
