BorHor's RHD 2JZ MK3 Build Thread.
IBoughtASupra
4,455
Queens, NY
The gearing will be horrible with the stock diff. I have never seen anyone write up how to do a six speed swap in a MKIII with a getrag but assuming some good fabrication skills and a welder, it can be done.
SupraClaou
846
4
Athens,Greece
The only way to put a 6 speed getrag on the mk3 Supra is to get the V161 trans (97-02 mk4s),which has longer
gears vs the V161 trans (93-97)....but shorter 6th gear. Also get big wheels (tire/rim combo),to help the gear also.
And if possible to find the 3.5 gear and pinion. A guy or two,do have this ring and pinion and they are a member of
Supramania.... Then it will be OK to have the 6 speed getrag!
88mk3supra
7M DEMON
May 23, 2009
390
Clayton,Ohio
sean joseph has the v161 in his mk3 his is sickk and speaking of big wheels hes got sum big volk gts wheels look amazing, borhor's wheels are just sexx! perfect stance
laotionracer101
389
Arkansas
I call BS no pics.. no believe C:
And do NOT even think about a t56.. they are weak! I have a few GM buddies and i asked them how stout they are.. They have already been through a few with just bolt-ons and the tranny's where built, its rather sad.
supra91gsxr06
58
buena park
LOL u want pics of my 6speed?
Bleakvoid
Wide-------------bodied
Oct 7, 2010
222
Fairfield, CA
The fbody community refers to the t56 as the rear-end sledgehammer...that tranny has destroyed more diffs from hard shifting than GM has put into those cars. Idk why anyone would call it weak, it's easily one of the more durable and versatile gearboxes of recent years.
On the other hand, the v160/161 bolts right up to a 2jz. It's meant to be. Plus, who doesn't want an entire mk4 drivetrain in their mk3?
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Looks like the 6 speed swap will be going in sooner then I thought. Will be a V160 with a carbonitics twin plate clutch. Going to run a 3.73 rear end for now but we do have a 6 speed rear end as well that may go in eventually. The main reason we are doing the swap is because our 5 speed is leaking so we figure why not upgrade lol. We do know the gearing is going to be crap but that is okay for now.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
lol t56 is way better priced cheaper clutch set ups easier to find...
i know plenty of people running them 1 in fact has 1 in a mk4 with 500 hp
i seen brand new! t56's for $1500 when can you find getrag for that price..?
tripple disk clutch set ups cost 2-3k for getrag
t56 I've seen specs for 1k
laotionracer101
389
Arkansas
nice tranny C: , Well obviously for less than half of the price you get less than half of the quality. If you want to hold power you have to baby it..
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Because this build is taking so long we keep adding more parts to make the build even longer! haha. Few more parts going on are authentic greddy intake manifold, 3.73 rear end with a TRD LSD, and maybe even a billet ball bearing pt67 turbo lol.
Flateric
946
Calgary, Alberta, Canada
No, I think you really should listen to the guys telling you not to go with the v160. So, since I am such a nice guy and all that and simply concerned about you having far too many parts just kicking around....I will take it from you,ok?
Going v160 is going to be awsome man. NICE!
I'll be watchin, be sure to give alot of detailed pics on the operation!
