IJ.;1472348 said:Define "over torqued"
NEVER had a tunnel issue using ARP's spec and Moly lube.
suprarich;1472355 said:1 axis vrs 2 axis?
IJ - Don't all 7m's come with a built in tunnel issue right from the factory?![]()
gottadiesel;1473155 said:So do I just go with ARP head and rod, drop the idea of the mains? It would save almost $200, if it is really a waste. But if I do swap them for ARPs sounds like it would not be a bad idea to line hone, but debate ably not absolutely necessary... Clear as mud...
suprarich;1473360 said:Your motor may need a line hone or bore even if stock hardware is used. Only your machinist will be able to tell you after he inspects the block. In most cases when using aftermarket bearings, I find that I will want to line bore the mains to make the bore all one size rather than the multi size crooked holes that toyota gives you. For a near stock (under 450 hp) build, I do not think arp mains will do anything for you. I however, do install them in every motor I do just because that is just me.
