BLOWN TURBO
MKIIINA
Destroyer of Turbos
Plano, TX
what color smoke? do you have any shaft play? how many miles are on the turbo? how many pounds were you running before?
REPORT BACK ON THESE THINGS AND THEN GET BACK TO US!
oh yea and turn off capslock
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
yeah my bad on the caps. i just bought the car so idk what it was running before. its black at idle and i can see some grey sometimes when iam driving. theres no shaft play. idk how many miles are on the turbo.
RTA Supra
MA70 Enthusiast
13
Tampa, FL
That's the same turbo I got with the car when I purchased it three years ago. I took it off when I went SC61 and put it back on about two months before I sold it to the guy you bought it from. I was running about 10psi on it when I sold it
MKIIINA
Destroyer of Turbos
Plano, TX
look at your ic pipes for a leak.
smoke cheat sheet:
black = fuel = rich
blue = oil
white = coolant
if theres no shaft play i would look somewhere else for your smoking issue. are you burning oil?
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
so if the seals in the turbo are blown, when would you most likely be burning oil? i've been seeing blue smoke comming out of my tail pipe here and there (i've noticed it twice, both times after driving around a little and then comming to a stop it'll smoke for a couple seconds..dont know if it smokes while boosting..gotta have someone drive behind me) and i don't like it one bit.
i wouldn't consider this threadjacking..its totally on topic;)
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
yes iam burning oil my buddy put his hand behind the ehaust and had oil sprayed all over his hand. so its blown. now is it cheaper to get a rebuilt ct26 or just get like i t4 upgrade cause i currently have no money so iam looking for the cheapest way?
MKIIINA
Destroyer of Turbos
Plano, TX
nope its on topic i think. honestly when my turbos have gone and i was smoking pretty bad (think fogging for mosquitos) and i didnt burn more than a 1/4 of a quart over a 200 mile drive. It looks like alot of oil is going up in smoke but its really not. I lost more through oil leaks on other cars over the years. but if you can have someone follow you and see if your smoking when you boost and usually right when you step away from a stop id start looking into the turbo.
hth
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
hth
thats what its doing i had my dad follow behind me the whole way home the other day and when i first leave and when it makes boost it smokes.
MA70Snowman
374
San Diego
I've got the 007 Smoke screen going too. but it only happens when I left OFF the gas after reaching boost (even 1-2 psi) and its usually linear.. more boost more smoke. but as long as i stay on the gas in boost.. no smoke.. but as soon as i let off.. about 1-2 seconds after POOF.. smoke all behind me. I've already found a replacment turbo. but just wanted some inputs on is it even my turbo or what else.
RTA Supra
MA70 Enthusiast
13
Tampa, FL
Lol, look at what you just wrote
at LEAST get a good ct from someone on here. The stock ct's are NOT fun to take on and off
Idealsupra
Orlando
www.tampabaysupras.com
gnarkill87 said:
do you guys know how long the cheap ebay turbos from china last?
you are wanting a cheap replacement...the best thing to do is find a stock ct on the forums..they go from arond 100-200 bucks for a good condition one.
anything other then that will run at least 500+ bucks.... and if you go to a t4 or such footprint it will require more parts be put on as it wont bolt to the stock manifold.
just find a stock ct.
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
if anyone has a good one for cheap ill buy it. but iam leaning toward just getting a new one cause the one thats on there now the guy said it was good and well its blown.
