Blown MHG?
supraman323
4
Florida
I have a metal headgasket (cometic) installed and my compression in cylinders 5 and 6 is at 90 (the others are 160)
Does a metal headgasket "blow" or am I looking at something more serious as a head issue?
Taking it apart now, any experience will help
airhead04
1,489
Lima, Ohio, United States
Did you do the piston rings in the engine?? They may not have sat right n those cylinders if the engine wasnt broken in properly. What was your final torque for the head? (meaning the head bolts)
supraman323
4
Florida
About a month... I'm not sure what would have caused it, just checked torque and the middle nuts were pretty loose, all others were at around 80 ft/lbs
I was only running 18psi, anyone know what a metal blown head gasket looks like?
How much of the head can I leave assembled as I remove it? I think i'm going to try leaving the exhaust manifold/turbo on, as well as the lower intake, shouldn't be more than 2 hours to find out what it looks like on my own
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
I usually leave the lower intake and take off the exhaust/turbo manifold because of weight. If you are capable of removing the head with turbo manifold and turbo then go for it.
Koenigturbo
1,337
Oxnard CA
If the middle bolts were lose and the rest tight, then would that cause the gasket to blow? Or warp the head?
Supracentral
10
Koenigturbo;1549623 said:
if the middle bolts were lose and the rest tight, then would that cause it to blow? Or warp the head? With the middle bolts lose, That could be the reason your gasket is blown.
I came here to say that. The long aluminum head on the Supra relies on even loading on ALL of those bolts. If any of them were loose, that's your problem.
supraman323
4
Florida
rivets were not removed, its a newer cometic so they are not touching the mating surfaces
nuts were retorqued at 200 miles, then 1000 miles
it has been about another 1000miles
How would the middle (4th row from front) nuts get loose?
I'm probably looking at a warped head then? I understand it is all speculation, but it's getting torn apart next Tuesday so I'll know for sure.
Koenigturbo
1,337
Oxnard CA
I'm probably looking at a warped head then? I understand it is all speculation, but it's getting torn apart next Tuesday so I'll know for sure.[/QUOTE]
only one way to find out.
This is a long shot: It may have been just be your loose bolts, that maybe your problem however at this point why chance it.
Koenigturbo
1,337
Oxnard CA
supraman323;1549567 said:
rings are fine, cooling system has lots of extra pressure, white smoke in exhaust so it is the headgasket
torqued to 82 ft/lb
Just curious: why did you go 82 l.b.s? and how did you arrive at that number? There has been "(research)" or someone arrived to the conclusion that M.H.G. for our cars should be 75 ft. l.b.s.
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
i thought arp specs should be used? iirc 85ft-lbs for studs?
i started a thread a while ago on this.
SideWinderGX
733
Syracuse, New York, United States
An 'exact' number has never been found or claimed by anyone. ARP says 85 ft-lbs IIRC.
It's more important to have the torque value be ENOUGH, than what it actually is. Generally that is about 75 and up. Some people go overboard and torque it to 100 ft-lbs, although I wouldn't personally do it...but they didn't have any problems with it after installed.
Koenigturbo
1,337
Oxnard CA
Kevin: I asked this question a while ago, I can't remember what the replies were on the torque spec or how they arrived at 75. I don't believe A.P.R. came up with that number, they just sell the bolts, don't don't give a shit what you torque them to, they have spec on what the bolts will hold up to, but they are not gonna have spec on what to "we" should torque them to, that's kinda up to us. I forgot that he used studs, if thats the case then, 85 is probaly right, altough I wouldn't know, I have the A.P.R. bolts.
Koenigturbo
1,337
Oxnard CA
SideWinderGX;1549942 said:
ARP sells these studs specifically for our cars, I'm pretty sure they put a little R&D into what the torque value should be ;)
SIDEWINDER: I guess, I owe you an appology: you are correct. 75 for the bolts and 80 for the nuts.
