Ok so heres a picture of the engine bay from a while ago...but this is pretty much the same as it is right now...
Could anyone point me out in the right direction? or what do i need to do guy?
But im getting the flutter when the blow off valve goes off (the compression surge type of flutter)... and i just realized now its actually sucking air in it seemed...
Can anyone help me out if they have done this before? point me in the right direction?
Somone helped me saw this in a mag:
"just finnished some reading. june 2003 SC mag pg 230. seems some diverter valves (same as blowofff valves but they send the air back before the turbo/maf sensor)are set up to suck air to by pass the unspooled turbo. goes on to say low spring pressure will open the valve. higher spring pressure will keep the valve close but slow response of the valve."
