Does anyone sell a block off plate for the device on the side of the intake manifold that coolant flows through?
The motor?:stickpokeCya said:Does anyone sell a block off plate for the device on the side of the intake manifold that coolant flows through?
shaeff said:if you don't know what the "device" is, then why are you trying to modify it?
that's my first question...
and to answer your question, and perhaps enlighten you a bit:
the "device" on the side of the intake manifold is the Idle Speed Control (commonly referred to as the ISC, or IAC, but we use ISC)
are you removing the ISC altogether? or do you just want to get rid of the coolant lines to the throttlebody and ISC? what's you plan?
if you just want to remove the coolant hoses, you can just buy a piece of hose of the same size from you local autoparts store, and loop it, bypassing both the TB and the ISC. it would go from below intake runner 2 or 3, to the small pipe leading to behind the head. loop, clamp, and be done with it.
if you're looking for an ISC blockoff plate, may i ask why you're doing this?
i remember someone selling them, but i can't remember who/where.
-shaeff
jimi87-t said:I know, I was just making a joke:biglaugh: I relocated mine, mounted it to the frame rail under my FFIM, this way I don't have something "hanging" on my mani, and I keep the smooth idle. It was a PITA to do though.
You're welcome!Cya said:thanks for the pics!!!!
supra90turbo said:Those bolts are too long. Not to mention they're not full thread.
You've got an ISC leak Jimi! Check that out.![]()
