Blew another HG
Fubar231
402
columbus
Mechanic just told me HG is leaking, had it done right before last time (Machined block/head with ARP Studs and MHG from Cometic)
This time, (CAR NEVER OVER-HEATED ONCE , not even halfway on the temp mark) but i figure this time the head/block should be good to go, get a new headgasket. Flush the oil/coolant and be good to go?
supramk3speed
305
Texas
Yeah that is strange, that really stinks for you buddy. If i blow another HG its out with the old and in with the new, 2jz swap anyone?
Fubar231
402
columbus
200$ for a headgasket, 2500+ for a 2j. + the mods i have in the car...
He told me that he was getting a lot of air in the cooling system... Said it rised with RPMS too. Hes gonna get back to me a little later.
Lemme quote what he told me
Rob said:
all i know is is there is alot for air coming from the cooling system into my funnel. and it gets worse with rpm.
reydio
181
Pearl City
I remember seeing somebody having problems with the cometic headgasket.
Quote from another user:
"i bought one from cometics a while ago, and it was about 140 i think for the HG... used arp studs, and had all settings correct, the seal was good to start, and less than 1000 miles later had BHG.... after pulling it to see the problem, apparently cometics has a bad stamp of gaskets, in which the rivet holding the multiple layers together is an 8th of an inch to far to the center, making half of it interfere with the seal of the head and the block... 78 ft/lbs of torque will make a brass rivet flatten out and put a nice semicircle in the head, and will cause a headgasket failure at that corner as well... go cometics!!! they didnt even reimburse me for anything and i couldnt get a replacement gasket out of them either for the troubles caused by their bad manufacturing, chalked it up to just another story of a company who doesnt care about customer satisfaction or quality products."
BigKO
326
Riverside
From what I've been told on here before, the Titan motorsports one you mentioned is just a re-badged cometic. I used it, but fortunately had heard about the rivet problem. HKS has a good reputation for being quality, but as you probably know they require a better RA than the cometic. I cant remember the exact numbers now, so i wont give you misinformation. Also you said you had the bock flat, did you have the RA (the roughness of the surface of the head and block) checked and verified? because your head and block could have very well been flat, but too rough. Hope that helps.
Fubar231
402
columbus
I don't exactly remember what all the specs were when it was machined. It was done last year, and i had a shop do it. Im startin to think they might of just taken my money. I told my mechanic to LMK if theres not head studs and a metal gasket in there, cause if not im startin a lawsuit.
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
reydio;1422181 said:
HKS.....expensive but proven.
+1 ive ran them in 2 of my supras 1 ended with rod knock and the current i have a bhg cause i didnt get the bottom end done, lasted 35xxxkm of daily DD for a year everyday and friday night races!
im going to use another hks this time again!
Fubar231
402
columbus
Yeah, my cometic lasted about 15k miles, daily driven and a lot, of late night racing. I cant emphasize enough of the late night racing part.
kamikazemkiii
1,219
North Carolina
You need to find out the problem or youll be nothing more then a parts replacer.
its weird but something just not right, best of luck ive got a BHG too i know it sucks
BigKO
326
Riverside
Its been covered before, and the general consensus seems to be that using a larger bore on the head gasket is ok, even if you didn't bore you're cylinders. If this is incorrect please tell me, but this is what I have read several times on here.
Fubar231
402
columbus
So what your sayin, is i can use a 86mm bore headgasket, with my stock 83mm bore and itll be good to go? ... ? Confuses me.
Fubar231
402
columbus
God i am so sick of problems with my god damn supra ... Its problem after problem, when i think i got one fixed a old one pops back up...
BigKO
326
Riverside
haha i think thats just the nature of old sports cars, and even more so with the supra. LOL well yeah thats pretty much what i am saying. It going to enlarge the opening there, and may slightly alter compression. It is not optimal but either way it should be just fine assuming all other factors are taken care of. Namely the machine work etc. Actually i just read about this, here:
http://www.supramania.com/forums/showthread.php?t=103765&page=5
the relevant part starts at post # 43 and the next few responses should give you the details.
