I originally had a 72mm ITS turbo on my 1JZ, and it was pretty lazy, I was seeing 18psi around 5300 rpms. Upping the Displacement from 2.5L to 3L would have decreased the spool time dramatically. But then I kinda started going overboard on the car
Bigzavs;1551682 said:I originally had a 72mm ITS turbo on my 1JZ, and it was pretty lazy, I was seeing 18psi around 5300 rpms. Upping the Displacement from 2.5L to 3L would have decreased the spool time dramatically. But then I kinda started going overboard on the car
nick88;1572908 said:White with a red pearl?![]()
honestabe;1573288 said:Progress, that's a good thing to be making. Why not fix the front bumper now that you have good easy access?
Bigzavs;1572816 said:Lexus code 1C6 - Graphite Gray Pearl
te72;1574411 said:My friend Andrew (the bastard that got me into the money pit I call Supras) had his car painted with that color back in 2004, but the car's been down for race car treatment since 2005...
Bigzavs;1578826 said:even better reason to change it, waiting for a call back on the paint code from the dealer now. not even sure if theyll give it out
update tho, motor is mounted, opened up the shifter hole, and it actually doesnt sit too far back, the center console still clears it (btw, was checking to see if the intake pipe would fit)
once i figure out my trans mount, the motor will come back out so i can finish the engine bay and get it ready for paint
