BHG job questions....
Kckazdude
1,239
Memphis, TN
I have always drilled the head off when this happens. Seen it happen a few times. Wasnt an uncommon occurance back when Toyota had the HG TSB/recall on certain V6's.
KongGMC
Shady tree mechanic
Nov 26, 2007
88
Crestview, Fl
I will probably try some of these things simultaneously like the epoxy and an oversized torx/allan bit. I really don't think an allan bit will work at this point cause it's like perfectly round on the top now and the metal is all very soft.
supramacist
1,501
The Grassy Knole
YES...., I know.
I was just trying to aid the guy in his quest of knowledge man.
I figure if you're going to try epoxy, use the good shtuff.
I See where I should have read a bit further. Thanks.
Go the Torx then!
Forget the epoxy it's not going to do jack shit other than make a mess.
Take Hommer's advice and retorque the remaining bolts to take some of the tension off the problem child.
KongGMC
Shady tree mechanic
Nov 26, 2007
88
Crestview, Fl
Well praise God, I got the rounded bolt out, took all remaining bolts out, and finally got the head to the machine shop! I'm extatic! I mean I've still got a LONG ways to go before it's back running, but atleast I'm at the half way point now. Now it just comes down to buying the stuff I need to get her running.
Thanks for the tips!!
KongGMC
Shady tree mechanic
Nov 26, 2007
88
Crestview, Fl
Well I took the camshaft out, tried to see if I could get a T-60 torx to fit but it was way too big, so I ended up taking a 10mm hex bit, beat it in with a hammer good and hard, tried tightening it a bit to see if I could maybe currect the bolt a bit and realized it had dug in real well, so I managed to get it out like that. I must have hit the thing pretty hard cause now I can't get the hex bit back out, LOL!
KongGMC
Shady tree mechanic
Nov 26, 2007
88
Crestview, Fl
No I could get to it just fine. There were a few bolts the cam blocked but I put the sprockets back on and turned the camshaft when I needed to.
Truth be told I don't know how I managed to get it to bite correctly other than it just being a straight up blessing. I don't care now though. I'm just glad it's over with. I have been worrying myself sick trying to think of some way to fix this.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Good for you man ;)
This is one of those cases where a hammer is actually the appropriate tool. Once the ARPs go on, there will be no more messing with hex heads!
HommerSimpson
1,067
New Smyrna Beach Florida
jdub;992135 said:
Good for you man ;)
lol im never gone live it down ... am i
O and very happy you got it out finaly :}
KongGMC
Shady tree mechanic
Nov 26, 2007
88
Crestview, Fl
Well I had decided against blowing $100+ on a set of ARP head bolts but I may have to rethink it if they are that much better. Lord knows I don't wanna ever be stuck in that situation again. Although, if I ever have another problem with the head gasket on this monster I probably will not dive into it again myself. Can't say it was overly hard, just a royal pain.
jdub
Feb 10, 2006
10,730
Valley of the Sun
The stock head bolts are pretty strong, but they have their limitations (as you found out).
Given a choice between ARP bolts vs studs...I'd choose the studs, no question.
