Well this is a new one to me.
Never actually had to deal with this monster, and now here it sits in my lap.
The car over heated on me last night. It had puked all the water out the over flow bottle.
I did a compression test. 160 accross the board. Ok.
Checked all the plugs. No water or coolant deposits. Ok.
I did a leak down test. #6 cyl has 3-4% leak down and is comming out of the radiator filler neck. Icky. :nono:
I understand that this is indeed a BHG. :cry: I also understand that detonation and poor engine building practices kill head gaskets.
This engine was built by an ex indy car engine builder. I personally saw the engine machined, prepped and assembled. No worries there.
Now...
What baffles me is how?
-Ive always been a little on the rich side of the engine's entire life (30k miles)
-The engine when built, had all new parts in it. The only thing that was left over from toyota was the block, head, crank, and oil pan.
-I have arp hardware through out the engine
-Im running a commetic 2.0mm head gasket
-Timing is and has always been 12 deg btdc
-The 440's that were on the car and the 550's that are on the car have been inspected by R/C
-Walbro pump, new.
-Aeromotive AFPR
-New fuel filter, Toyota
-Stock cpu
-Always been turbo timed
-NEVER AND I MEAN NEVER have I ran any thing less than 93 in this car
-Autolight 3923 plugs for the life of the engine
-Mobil one 15w50
-EGR is plugged at the back of the head, no cooler
-All head bolts were at 75lbs of torque (and yes I checked them)
-Ive never ran more than 14psi on a 57 trim ct26, and now with the monster on here Ive never ran more than 10psi.
-Ive never encountered a boost spike
Im off to put on the new gasket here this week.
If any one has some light to shed on how this could have happend, please discuss.
Now...
-Walbro pump, new.
-Aeromotive AFPR
-Stock cpu
-Mobil one 15w50
