Best Turbo Award!!!!!
jtamulis
www.NotRice.com
Apr 9, 2005
537
Pittsboro, NC
www.NotRice.com
Do you guys even LOOK at the group buy threads?
How about a sweet 450rwhp daily driver turbo on pump gas, and a 525-550
rwhp turbo on race gas, bolts on to the stock manifold, with everything you
need to put it on the car for less than Suprasport's BOSS Turbo's P-Trims START
at cost wise, has the same exact Stainless rear housing (from LIPP), and is
basicly the exact same turbo, but less $$$$.
http://www.supramania.com/forums/showthread.php?t=20682
I'm doing this turbo for darn near cost. It starts making boost under 2300rpm
makes full boost below 4k, and makes 450rwhp easily on pump gas.
Also check out Rich's rebuild thread (Rich87Tx2) for more info.
I've owned a dozen MKIIIs, and when I had my 454rwhp MKIII (using basicly this turbo),
I couldn't have been happier. And normally the turbo alone is $1500, but I'm doing all
the 4" intake, K&N, silicone couplers, SHIPPING, etc. for 1500.
Jeff
jtamulis
www.NotRice.com
Apr 9, 2005
537
Pittsboro, NC
www.NotRice.com
I know everyone has opinions like assholes, but, in my humble opinion,
this turbo is the best all around STREET turbo for the MKIII. Gobs of
power, spools up quick, comes on smooth, not sharp (handy for street
cars). Makes 500rwhp. Pretty much ideal for a street driven MKIII.
NJsupraA70
Ex-Supra Owner
Sep 18, 2005
276
NJ
The new Sp HOBB bolt on's that just came out are really sweet. I believe your getting much more for you money compared to the Boss series if your looking to spend that much money on a bolt on..
http://supraforums.com/forum/showthread.php?t=370899
jtamulis
www.NotRice.com
Apr 9, 2005
537
Pittsboro, NC
www.NotRice.com
You're kidding right? $2300. With no intake, an exhaust housing that's been
re-drilled, its cast, not stainless. The JT62 comes with the intake, SHIPPING,
you can get an anti-surge housing if you want. bolts onto the stock manifold
requiring no fabrication, normal 3" ehaust elbows, makes the same power, and
costs $800 less. Thanks, but I'd rather just get mine converted to BB for an
extra $300, and take that $500 extra money, and buy a MAFT-Pro setup to
go with it. Now if you're comparing it to a normall BOSS-550 from suprasport,
Then I'd have to just shut my trap and agree with you. But I think the BOSS
series is a higher quality piece than the SP61. But it costs more. Mine is the
same quality as the BOSS (basicly it IS the BOSS), but costs less than the
SP61GTBB
Jeff
MKIIINA
Destroyer of Turbos
Plano, TX
but arent you doing a group buy and normally your setup doesnt come with those things? this comes with an externally vented wg, new dp, bolts to the stock mani. plus there is an internally gated version coming out soon that will be the same as the sp61gt but with a water cooled dbb centersection that should cost less. {shrug} just my 2 psi
turboa7mgte
HECK YES I DID!!!
Delavan, WI.
SP61GTBB
Jeff
Our New SP61gtBBHO kit comes with everything but an intake.... Plus its fully heat coated and polished. I made this turbo for another option for you guys! Is it for evorybody? no! I will put my 61 kit up against any other 61 kit out there. I also have a 67 kit in the BBHO series that I will be testing as well.
I am having some new exhaust housings cut for the BB full bolt on brother to the SP61gt for $300 more than the standard version. I am looking for this to happen in the next month or so.
There is much more to come from SP for the 7m and 1j!
Tim@SP
Guys: This is starting to sound like one of thoese ads on TV where some dude in a bad suit Yells at you to "buy this buy this it's bigger better faster buy this NOW!!!! "
I'm just waiting for the free steak knife offer........
