Bearings anyone?
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
Well I have this problem with wanting to assemble my 7m and put it into my car.. buttt.. The toyota crank and rod bearings have been put on backorder till june 24th! :aigo:
They have gotten in 6 of the crank bearings (1 still on backorder) and they have 3 of the rod bearings (3 still on backoder)
At this point Im now wondering if I should just buy aftermarket bearings and get the machine work done to make them fit correctly..?
Only thing is if I do that ill be re-doing work to fit all the aftermarket bearings. Already had the rods resized since I installed ARP rod bolts and had the crank checked and repolished. Fuckk this is really pissing me off, Toyota Canada SUCKS!
Does anyone know if Toyota in the US has any of these #3 bearings?
Part Numbers of the bearings I still need are.
#11701-43010-03 ---> One of these (crank bearing)
#13041-42010-03 ---> Three of these (rod bearings)
BTW this is for an 87 7mgte.. If anyone could help me out I would apprieciate it so much!! If I have to wait till the end of june for parts I will barely get to drive the supra this year. :( :(
If anyone had suggestions or advice throw throw it up, im pretty much screwed at this point in my build :(
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Ya your best bet is finding someone in the US to buy them for you and send them over. You really want to stick with Toyota bearings as much as possible if you can, no point in going to standard sizes when you are all ready for Toyota bearings.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
If nobody else volunteers i can see if my local dealer will get them for me then send them to you. Is the part number specific to the #3 bearing you are looking for or do i need to specify?
DangoAZ
Driver
Jun 13, 2007
71
Flagstaff, AZ
Try giving a phone call over to Aaron at Driftmotion. I needed all #2 or #3 sized Toyota bearings for my rods and crank, and ended up ordering a set of Clevite 77's from Driftmotion. After talking on the phone with Aaron, he gave me the confidence to try them. After putting them together and checking with plastigauge, everything was within tolerance. If you're not willing to wait, it could be an option. You're only out the time of a phone call for weighing your options.
PS - I'm only planning a BPU motor... nothing crazy. Your options could depend on your power goals and your confidence in other-than-Toyota parts.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Let me know what you plan on doing im willing to help you out for free, but i dont want to run around for no reason. So just let me know if you want to use Toyota bearings and i will get some prices for you/order them and ship them to you.
svnmpwr1990
47
San Angelo
i will see if my local toyota shop can get them if cify cant get them just pm me if he is unable to help i wont charge you any extra just whatever the parts cost plus shipping
I went through this with my build, I bought a good number of the bearings they had left in the US/Canada and they had to get some shipped from japan :( The supply is drying up since Toyota doesn't keep them stocked here because not too many people buy them
BigKO
326
Riverside
Strange I must have gotten lucky because I got all of mine within three days, and that was what my dealer called a backorder... Ordered Mon, they were there on Thursd. Picked em up Fri...
BigKO
326
Riverside
haha good point didn;t consider that ;)
I do have Clevites, but considering that everything is all ready for the Toyota bearings, you prolly don't want them.. but as a LAST RESORT, I have a full set of main and rod standard sized bearings. Bought these then decided to go Toyota OEM just as you did...
BigKO
326
Riverside
Mk3runner;1321205 said:
Toyota bearing ftw
haha definitely cannot be too bad, they lasted 200,000 miles the first time around no problem... lol well I'm exaggerating just under 189,000 lol
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
I belive toyota bearings would be the best for my build since the plan is to put down some pretty decent numbers. Also I already have 9 of the 13 bearings needed, so going with clevites would be somewhat silly since I cant return them to toyota.
CyFi6 if you could check out prices and availability for me on the bearings, I am commited on getting them. All the info on the bearings needed I put up in the first post.
Thanks for all the help :)
Chris
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
black89t;1322085 said:
champion is your best bet. just ask for jeff and only jeff. he deals with supra parts every day. he was able to hunt down a first gear for me which my local dealership told me no longer existed.
I've had very good luck with Micheal Horne.
