Well I have this problem with wanting to assemble my 7m and put it into my car.. buttt.. The toyota crank and rod bearings have been put on backorder till june 24th! :aigo:
They have gotten in 6 of the crank bearings (1 still on backorder) and they have 3 of the rod bearings (3 still on backoder)
At this point Im now wondering if I should just buy aftermarket bearings and get the machine work done to make them fit correctly..?
Only thing is if I do that ill be re-doing work to fit all the aftermarket bearings. Already had the rods resized since I installed ARP rod bolts and had the crank checked and repolished. Fuckk this is really pissing me off, Toyota Canada SUCKS!
Does anyone know if Toyota in the US has any of these #3 bearings?
Part Numbers of the bearings I still need are.
#11701-43010-03 ---> One of these (crank bearing)
#13041-42010-03 ---> Three of these (rod bearings)
BTW this is for an 87 7mgte.. If anyone could help me out I would apprieciate it so much!! If I have to wait till the end of june for parts I will barely get to drive the supra this year.
If anyone had suggestions or advice throw throw it up, im pretty much screwed at this point in my build
