ARP head bolt tool????
mk3tattoos
1,104
Bremerton, Wa
what is the tool called and size that i need for the ARP bolt? just trying to get everything i need to retorqe the head if it needs it. thank you
89supra7mgte
797
colorado
dont waste the money on snap on unless you work on cars for a living or expect to use the socket for more than the bolts. Craftsman, come with lifetime guarantee and for that one socket save you about 40-50 dollars. Mine as well did not slip when i did my head gasket.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
89nasupra;1549581 said:
I used a 3/8 drive torque wrench that maxed out at 100 ft lbs. So i took in to consideration for not being very accurate plus twist from the extension 95 ft lbs seemed like a good number to go with.
Having extensions wont affect the final torque , they do twist but your torque wrench wont click until there is the set torque on the actual bolt
fixitman04
fixer of all things !!
Sep 18, 2008
787
north dakota
incorrect! the torque wrench measures torque at the head of the wrench, the twisting of the extension will effect final torque as it twists exponentially and applies a different torque at the socket end. this is why it is harder to get a bolt off with a longer extension. this is especially so with a smaller size wrench. i recommend a 1/2" drive torque wrench with as little extension as possible.
there is a formula for figuring out exactly how it effects the final setting, but i cant find it right now!
89nasupra
Sugar, Water, Purple
Apr 8, 2008
501
Lafayette, Louisiana, United States
It has been like this for 6 months now. The longest my car has run between tare downs. I wanted the extra piece of mind knowing they are tight.
Northbaysupra,
I did this with out looking for repercussions on here. Don't go to 95 thinking it is the right thing. I did this on MY car. I would recommend you follow the propper steps and torque values provided by ARP. My bolts were on then taken back down then put back on. If you are starting fresh, follow ARP specs.
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
honolulu, california
The formula is:
S = handle setting
T = torque applied at end of adapter
La = Length of handle in inches
Ea = Length of extension in inches
S = TxLa/(La+Ea)
If the extension you are using is more than 2in. in length you need to use this formula (i.e. an extended crows foot). A regular 6in. extension that allows for access to deeply recessed bolts you do not need to use this formula.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Are you guys talking about extensions as in increasing leverage or extension meaning 90 degrees from the torque wrench?
Im pretty sure OP is talking about length extension so he can get into the recessed area:
not this kind of extension:
Don't know who told you this, but is is way wrong. A straight extension on a socket does not have a significant effect on setting torque.
Northbaysupra,
I'm glad you posted this disclaimer. Here's why: ARP bolts are limited to 75 ft/lbs on an aluminum head due to the difference in heat expansion for aluminum vs the steel block. 95 Ft/lbs is almost a 20% over torque...that greatly reduced the safety margin ARP has designed for their bolts. More is not better when setting head bolt or stud torque values ;)
PROJECT N00b;1550024 said:
The formula is:
S = handle setting
S = TxLa/(La+Ea)
QFT ;)
fixitman04
Sep 18, 2008
787
north dakota
dont know where you are getting your info , but i am right. do a little experiment. with a good torque wrench tighten a bolt to 100 ft-lb with a 12 " extension, then check it with the same setting on the same wrench without the extension. you will have to tighten it up at least a 1/8 of a turn to reach the same torque. i got my information in multiple places including machinist school. it is called torsional deflection. ever seen tire torque sticks.. this is how they work.
