OfnaRcR4 said:ppl usually to 78-80 or more. Never do 58 haha.
RedDogOIF said:^ really
phoenix6 said:bwahahaa damn who said 60? 58ft lbs is partially the reason every 7m still stock blows its damn HG. 75 - 85ft lbs, ur safe, trust us haha. Also, tap the holes b4 u put in the arps, to get an accurate torquing.
RedDogOIF said:Yup, tapped the holes with a 12mm/ 1.25 thread chase. I'll do 75 so that I'm not going through this fun right after I finish. Thanks.
jdub said:Uhhh...how about using the ARP torque spec like you're suppose to.
jdub said:Ummm...no.
There's a sheet that comes with the bolts/studs...that is the torque you use. You guys need to stop guessing or using "I heard" specs for this kind of stuff. Reading the install/spec sheets for the equipment you use is pretty simple
http://www.supramania.com/forums/attachment.php?attachmentid=8053&d=1152461120
jdub said:You can do whatever you want, but to say or to come across as "this is the spec" is wrong....the spec sheet is there for a reason. It is based on 75% of the yield strength of the bolt to provide a buffer against failure. Exceed the torque and you get closer to the design limit of the bolt....something ARP specifically warns against doing.
This is actually the latest sheet:
If you don't know...STFU
You're not helping anyone posting the wrong info.
jdub said:
Can't help being blunt...it's my nature. Hope you learned something.
