arizzle's 92 teal project2!
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
VanSupra;1537304 said:
Hey anytime Aries..White on burgandy is nice..lol..
hahhaa i think ill have to pass! my black supra was black on burgandy lol
Grimsta;1537647 said:
NIce build Arizzle. I remembering talking to you, never looked at your build. What turbo are you running?
thanks man, yeah i ended up finding the rad locally (thanks vansupra), as for the turbo im running a turbonetics 60-1trim, cold side .68AR and hotside is .70AR, its a pretty quick spooling turbo.
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
well bit of a update!
the supra broke down lastnight!!!! i was going up a hill and just lost all power. while waiting for the tow truck i tried to diagnose as much as i can with minimal tools lol!
well heres the run down i need a bit of help !
got spark, got fuel pressure, got compression. now heres the issue. i got fuel pressure in the rail but when i took the spark plug out it was bone dry!! i didnt get a chance to check for codes. thats what i will be doing tonight.
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
well figured out the problem, it happened to be a big fail on my end.
well cars up and running now. i got the stock coils and new plugs in and started up good. im going to check the condtion on the 2jz coils cause it had a rough idle so im not sure if that was it.
my maft-pro is acting up as everytime i touch the unit it jumps really rich, when i touch the map sensor the car just dies! im going to be checking the wiring to the 2 units and try and make the connections tighter.
now that i've got the car up and running again i got a few future plans hopefully before PNW!
plans:
TUNE
WHEELS
PAINT
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
^^hey sorry yeah my photobucket moved all the pictures around so now there all different links.
update.
stuff i've been up to for the past month.
installed a nustart alarm w/ 2way
installed a apline 6.5 indash
installed apline 6.5 w/ component speakers
installed a walbro 255lph
installed a lotek pod w/ AM cobalt boost and AM cobalt egt
mounted new wheels!
enkei RP03 SBC 18x9+18 / 18x10+22
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
Looking hotter every time I pop in here, what is your suspension setup that gives you that stance? Also what kinda of tire you got on the rims, the back seems a little stretched to me...
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
thanks man,
just H&R springs with stock struts been fine for a while now, but the rear needs mooarrr loow! :evil2:
as for tires. front 235/40/18 and the rear is a 255/35/18 plenty of contact on the road :icon_bigg
