Make sure you do not have a MAP issue either. Check and recheck your vacuum lines. I replaced all of mine, one at a time by the TSRM. Sounds like the spark is solid now, but you are over fueling. Wide band is a must for tuning anyway.
91TurboDave;1755967 said:Make sure you do not have a MAP issue either. Check and recheck your vacuum lines. I replaced all of mine, one at a time by the TSRM. Sounds like the spark is solid now, but you are over fueling. Wide band is a must for tuning anyway.
91TurboDave;1755970 said:The down and dirty way is to pull your Fuel pump resistor, or disconnect your relay if you did the 12 volt mod (which I HIGHLY recommend). Then have someone crank the car while you have a magnetic induction test light hooked up to your pulse wire (note sure which color, either should trigger a blink, and see how long the light flickers. If it stays on you have a pulse trigger issue. I would think it is a bad pressure regulator though.
ifyouaint1sturlast;1754172 said:Tomorrow I'm going to diagnose everything as best I can. I have a 21 item list of things to check.
Honestly though. I just realized.. the symptom I'm describing where the car just stops cranking for a second.. I think it's hydro lock from gasoline because I'm smelling gas HEAVILY. It all makes sense now.
That helps me because now I believe either:
a) The car is spraying too much fuel, trouble areas: FPR, what else?
b) The car is not igniting the fuel, trouble areas: Coil packs, spark plugs, ground? (could bad ecu grounds cause weak spark?)
I think the second option is the more obvious of the two, however I nabbed an FPR off a 2JZ-GE at the junkyard and maybe I'll throw it on just to notch that off the list.
ifyouaint1sturlast;1755975 said:Ok. How's this..
I'll get the AFPR hooked up, and go from there?
91TurboDave;1755976 said:Double post deleted
---------- Post added at 06:17 PM ---------- Previous post was at 06:16 PM ----------
You need a Wide band to tune your AFPR
ifyouaint1sturlast;1756006 said:Do I? Since I'm running stock injectors can't I just adjust the AFPR to the stock pressure setting? (32PSI IIRC)
Thanks for all your help Dave this is really helping me get my car going.![]()
