Ok, so..
Just completed my Aristo swap into my 90 MKIII. It starts and runs, but a few problems..
1) Sometimes when starting, the starter will struggle to continue cranking, if I let go of the key it sounds as if the engine completes the revolution (or spins backwards) .. indicating timing is off?
2) On occasion turning the key I just hear the click click and the car doesn't crank. If I keep trying it will eventually crank over.
3) Once the engine is running, it will not stay alive if I let off the gas pedal. If I just barely touch the pedal it will stay running at 800-1000.. but still has the misfire that I'm about to describe. I've narrowed this to be that the flapper valve for the ISCV *may* be installed incorrectly but I'll be checking that out tomorrow.
4) When trying to idle, the RPM fluctuates badly. It definitely has a miss. It sounds like a cammed up drag car or something. My friend seems to think it's one of the injectors not firing or something. I removed the fuel rail and placed it on rags and cranked the motor. All injectors sprayed a fine mist of fuel, it looked to be working fairly well. Something I'm concerned with is fuel pressure. I have no way to test it and my pump is running on 12v. I can't help but feel fuel pressure is way too high.
Specs:
-1990 Supra MKIII
-Aristo 2JZ-GTE
-Completely stock (440cc) fuel system on motor
-Single Walbro pump
-Motor is single turbo'd
Checked:
-Codes. No codes are stored. Just blinks forever and ever.
-TPS is checked/adjusted to TSRM
-ISCV clicks when the engine is turned off
-Couldn't find any vac leaks
-Checked/verified power/gnd of MAP sensor, all injectors, all coil packs, crank sensor and cam sensors
-Checked/verified resistance of all injectors, all coil packs, crank sensor and cam sensors
-Checked valve timing (all three sprockets at 0deg TDC, verified TDC with chopstick)
-Replaced spark plugs
-Replaced o2 sensor
Not really sure what to do next. Was going to check for IGF but if the ECU wasn't getting it the engine would stall, right? I really want to verify the waveform of the crank/cam sensors but have no access to a scope (perhaps the signal is being interrupted by bad wire extension, or extension interrupted the shielded wiring?) I was thinking next of buying some length of good shielded wiring and running new wires from those three sensors to test if it changes anything.
I feel that I'm looking so hard that I'm overlooking something. Would love everyone's input.
Any help is appreciated,
Thanks!
Video:
Specs:
-1990 Supra MKIII
-Aristo 2JZ-GTE
-Single Walbro pump
Checked:
-Replaced o2 sensor
Thanks!
Video:
