another attempt at 600rwhp
malloynx
NC
well i have been struggling at the dyno lately. 543 so far is the best i can muster.
i had to go to my thinking lab :) and i feel i got the soulution for 600rwhp+. i got a new stock manifold installed with a malloy secrect sauce port done to it and i got a new exuast setup.
tuning is going to be a huge part and i feel pretty confindent with the methanol now.
i'm shooting for 625rwhp+ on the stocker and i'm confident i can get it done, on a total bolt-on setup.
i'm going to be hitting the dyno soon and i'm sure brent will be there to film it.
just wanted to give a heads-up that i'm still trying for this goal.
btw.. i plan on running 30psi :) :)
SySt
Burnsville, Minnesota
I would definitly consider some head work and a cam. Just make sure with the cam that there is little is any actual overlap or you'll lose boost through the exhaust manifold.
X-man
member
Dec 5, 2005
309
Pulaski,Va
Good luck with your attempt and it will be nice to see another 7m in the 600+ rwhp numbers. The stock cams and head are fine. If I could have turned alittle more rpm past 6700 I believe I could have broke 700 rwhp. I was still making power at my 6700 rpm redline.
Sean
malloynx
NC
yea, head and cams are both stock and will remain stock. i want to do this on a bolt-on setup.
x-man we dyno in charlotte at CPRACE.
brent,, i wasn't trying to put words in your mouth.. ;)btw I got those tires ready for you.
MRSUPRA
838
Maryland
Good luck, I hope you do it. It will be real interesting what you can squeeze out of that stock ex. manifold. Will Neely did 684rwhp with a T66/HKS manifold, stock cams but lots of head work including oversize valves. X-man di 637rwhp with a stock 7M with a HKS manifold and SP67 but with a FF intake manifold.
Do you know what size turbine wheel you have? Is it a P-trim?
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
will neely did those numbers with a sound performance kit. (sound performance exhaust manifold) the turbo was a t-66 like u said but not with a hks manifold
malloynx
NC
hey matt, my turbo is not a p-trim. i got the stage 5. i know this turbo can do it easliy. i just been having some bugs worked out.
i thought it be alot easier to hit 600 but it's not.. lol.. i'm feel real good about my setup now and i think i got everything sorted out,, :)
i'll keep everyone posted
MRSUPRA
838
Maryland
"will neely did those numbers with a sound performance kit. (sound performance exhaust manifold) the turbo was a t-66 like u said but not with a hks manifold"
My fault. I thought he listed it as a HKS manifold. Either way, each will support well over 700rwhp.
Hey Malloy, I thought you were using a smaller turbine wheel. The spool looked way too good for a p-trim. I definantly want to see another dyno gragh, hopefully a little clearer than the last one.
