Annoying Window Rattle
JDMMA70
2,550
Houston
Wait so if my window is 3/4 of the way down it should rattle? ill have to try that, i never really noticed any rattle? Im assuming this happens while driving.
Satan
Tampa
Supra-Man18;1389428 said:
LMAO wow !! THere are PLENTY supras With this problem i see.. And so far the best solution is all the way down or all the way up ! lmao xD
I hear rattling in either position. I never have the windows anywhere inbetween. Just all the way up, or all the way down.
Would definitely like a parts list to knock this issue out.... Maybe we could even do a write-up for replacing the pieces and adjusting the window (if there's not already one out there).
rakkasan
Currahee!!
Fort Campbell, KY
I've looked high and low, but I can't find the invoice with all of the parts required, however, I'll dig into the boxes I store my parts in and get the parts nos tonight if possible....
rakkasan
Currahee!!
Fort Campbell, KY
67241-14021 - stabilizer, door glass, inner (1 ea door)
90209-09005, standard part (window bushing, 4 sets ea door)
69801-14100 - regulator sub assy, front door window, RH
69802-14100 - regulator sub assy, front door window, LH
91651-40612(2) - standard part (regulator guide channel, 1 ea door)
69981-14020 - roller, front door glass guide (1 ea door)
This is what I found, bounce this off what Jeff recommends, I might not have everything needed now.....
Also, the EPC showing parts....
Satan
Tampa
...resurrecting the thread.
I hadn't gotten to this project yet, but think it'd be a good one to do over the Winter.
Did anyone else order/document all the pieces/prices needed for this work...?
Write-ups or tips?
dusthead
C-C-C-C-COMBO BREAKERRRRR
Aug 10, 2009
100
New London, CT
i'll second that...
plus a pic of the damn bushings...can't find them with the window all the way down...battery is missing...so i think i'm screwed without it.
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
i'd love to see into this. I hate how there is so much play with the windows. every time it goes up and down it makes squeaky noise
terror
Antibliss
Jun 13, 2008
242
Alaska
ya a write up would be nice if anyone wants to do it, my windows so loose that it will actually rotate about 50 degrees, no bueno. sounds like i need a new everything
Satan
Tampa
Soon as I can find time to put together the parts list, I can see what the cost/turn-around is from Toyota.
I have a targa leak I can't fix and am now going to replace the actual targa istelf (w/leak fix already done), fix/adjust the windows, and add weather sealant in those areas in at the top of the pillars, that may also be prone to leaks.
Satan
Tampa
I looked in the other 2 pages of the thread and could not find the link to the parts diagram (the break out)... Wanted to get a list together and see what the Toyota vendors could do, so that I can get to this project soon
Please post the link to the door/window parts diagram where I can see all the part numbers to place an order.
THX!
Satan
Tampa
Thanks Rakkassan, I saw the EPC http://cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=6704&P=1 link you had. I also grabbed the parts list and pricing from www.toyodiy.com --- http://www.toyodiy.com/parts/p_U_199101_TOYOTA_SUPRA_MA70L-BJMVZA_6704.html
This other parts catalog lets me select the part on either side of the screen and highlights it on the diagram or list on the opposite side of the screen. Makes it much easier to see what the part is and where it goes.
This is everything that listed at about $706 (not including the door hinges). but I know that I would not be replacing the regulator ($146 x2), or the plates @$27 each. So, look at the EPC and this parts list and if you are wanting to refresh the grommets/washers, select just about everything at the top of the diagrams. You probably want to open the door up and see what you think you really need 1st... You may not need the stopper, trim support, or plate (68117B) and can save even more. Comes to less than $100 to replace the grommets/washers, etc, not including the regulator and other hardware you may already have.
I created a CSV file (open with Excel) to list/track the pieces I'd get and expected cost...add the regulators and hinges and you should be all set... http://www.g099521.net/pics/window.csv
STOP, FRONT DOOR WINDOW, UPPER 67211-20020 MA70 4 $7.37
SUPPORT, FRONT DOOR TRIM 67231-20020 MA70; RH 2 $18.08
SUPPORT, FRONT DOOR TRIM 67232-20020 MA70; LH 2 $18.08
STABILIZER, DOOR GLASS, INNER 67241-14021 MA70 2
PLATE, FRONT DOOR GLASS, RH 68117-14020 MA70 1 $27.26
PLATE, FRONT DOOR GLASS, LH 68118-14020 MA70 1 $27.26
STOP, FRONT DOOR GLASS, UPPER 68147-14020 MA70 4 $11.21
STABILIZER, FRONT DOOR GLASS MALE 68149-20010 MA70 4 $10.89
REGULATOR SUB-ASSY, FRONT DOOR WINDOW, RH 69801-14100 MA70 1 $146.20
REGULATOR SUB-ASSY, FRONT DOOR WINDOW, LH 69802-14100 MA70 1 $146.20
BRACKET SUB-ASSY, FRONT DOOR GLASS, RH 69901-14060 MA70 1 $20.19
BRACKET SUB-ASSY, FRONT DOOR GLASS, LH 69902-14040 MA70 1 $20.19
ROLLER, FRONT DOOR GLASS GUIDE 69981-14020 MA70 2 $6.83
90105-08115 *** STD. PART $1.29
90116-06043 *** STD. PART $1.29
90119-08012 *** STD. PART $1.87
90119-08573 *** STD. PART $1.51
90168-50040 *** STD. PART $1.66
90179-06033 *** STD. PART $2.63
90179-06070 *** STD. PART $0.89
90209-07001 *** STD. PART $0.94
90209-08014 *** STD. PART $1.52
90209-09005 *** STD. PART $1.91
90541-07024 *** STD. PART $2.53
91611-60614 *** STD. PART $1.28
91611-60616 *** STD. PART $1.17
91651-40612 *** STD. PART $1.47
