Thanks Rakkassan, I saw the EPC
http://cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=6704&P=1 link you had. I also grabbed the parts list and pricing from
www.toyodiy.com ---
http://www.toyodiy.com/parts/p_U_199101_TOYOTA_SUPRA_MA70L-BJMVZA_6704.html
This other parts catalog lets me select the part on either side of the screen and highlights it on the diagram or list on the opposite side of the screen. Makes it much easier to see what the part is and where it goes.
This is everything that listed at about $706 (not including the door hinges). but I know that I would not be replacing the regulator ($146 x2), or the plates @$27 each. So, look at the EPC and this parts list and if you are wanting to refresh the grommets/washers, select just about everything at the top of the diagrams. You probably want to open the door up and see what you think you really need 1st... You may not need the stopper, trim support, or plate (68117B) and can save even more. Comes to less than $100 to replace the grommets/washers, etc, not including the regulator and other hardware you may already have.
I created a CSV file (open with Excel) to list/track the pieces I'd get and expected cost...add the regulators and hinges and you should be all set...
http://www.g099521.net/pics/window.csv
STOP, FRONT DOOR WINDOW, UPPER 67211-20020 MA70 4 $7.37
SUPPORT, FRONT DOOR TRIM 67231-20020 MA70; RH 2 $18.08
SUPPORT, FRONT DOOR TRIM 67232-20020 MA70; LH 2 $18.08
STABILIZER, DOOR GLASS, INNER 67241-14021 MA70 2
PLATE, FRONT DOOR GLASS, RH 68117-14020 MA70 1 $27.26
PLATE, FRONT DOOR GLASS, LH 68118-14020 MA70 1 $27.26
STOP, FRONT DOOR GLASS, UPPER 68147-14020 MA70 4 $11.21
STABILIZER, FRONT DOOR GLASS MALE 68149-20010 MA70 4 $10.89
REGULATOR SUB-ASSY, FRONT DOOR WINDOW, RH 69801-14100 MA70 1 $146.20
REGULATOR SUB-ASSY, FRONT DOOR WINDOW, LH 69802-14100 MA70 1 $146.20
BRACKET SUB-ASSY, FRONT DOOR GLASS, RH 69901-14060 MA70 1 $20.19
BRACKET SUB-ASSY, FRONT DOOR GLASS, LH 69902-14040 MA70 1 $20.19
ROLLER, FRONT DOOR GLASS GUIDE 69981-14020 MA70 2 $6.83
90105-08115 *** STD. PART $1.29
90116-06043 *** STD. PART $1.29
90119-08012 *** STD. PART $1.87
90119-08573 *** STD. PART $1.51
90168-50040 *** STD. PART $1.66
90179-06033 *** STD. PART $2.63
90179-06070 *** STD. PART $0.89
90209-07001 *** STD. PART $0.94
90209-08014 *** STD. PART $1.52
90209-09005 *** STD. PART $1.91
90541-07024 *** STD. PART $2.53
91611-60614 *** STD. PART $1.28
91611-60616 *** STD. PART $1.17
91651-40612 *** STD. PART $1.47
