Andrew MKIII FULL All Mods and customade Front Face Inatke Manifod 7MGTE
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Yes need to relocate the battery, may be we can build one that no need to, but need to be with the stock tb :S but we need to try it
supraguy@aol;1988373 said:
I really like that your manifold allows the use of ac.
That was always a dealbreaker for me. I assume that it requires a battery relocation though, yes?
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Time to wire the positive wire
[/URL]
You got Mail!!!
We receive the flange turbo spacer, so time to instal the turbo :evil2:
We have some problem to install the flange, because the hole dotr the srews are not aigned :S so we need to perofome some rework, daaaammm I like plug and play things :: angry ::
After few time finaly finish :biglaugh:
charman02
Cruiser
Oct 14, 2008
121
Fresno
Looks good. That turbo looks like the Boss Sr. Turbo P-trim??? I didn't have any clearance issue with mine, the turbo intake housing was clocked differently, it was a little tight but enough. And mine had uncontrollable boost due to the dividing plate between exhaust turbine and waste gate. It kept on boosting over 18psi which was my fuel cut setting. If u want to at least control boost starting at around 15-16psi, it'll be a good idea to have a machine shop shave the piece down a bit
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Tks charman02, will check that :D
evil_shenron
64
santa maria
Turbo was assembled by Jtamulis. Exhaust housing and braided lines came from Lipp. Everything else he acquired from somewhere else. All garret internals I believe. 62-1 wheel with 4 inch inlet with dbb. Exhaust is a ptrim.
