Well...you really didn't tell me why, other than you "figured". I don't mean to jump on you man, but this is the reason guys do the things they do concerning oil. It's not based on anything but a "gut feeling". You do have the right idea for choosing an oil for cold start...a few specifics are in order though
To answer your question, a 40W multigrade is not more stable at ops temp than a 30W multigrade...any high quality PAO or ester based synthetic will handle any amount of heat an internal combustion engine can throw at it...the 40W is simply thicker. Therefore it will also be thicker at ops temp...this is not necessarily a good thing on a stock or mildly modified motor. Thicker oil has a higher resistance to flow; this is going to give you higher psi readings, but you are not getting better flow. The only thing a thicker oil will do for you is thin less at higher temps above what you would see normally (100 deg C)...for 90% of the motors out there, this is not a factor.
Keep in mind the 7M was designed to run a 30W multigrade oil...you're looking at viscosity in the 9.30-12.49 cst range. What you want is an oil that is thin as possible cold and provides a viscosity in this range at 100 deg C.
Here's a comparison of the 2 Amsoil oils:
5W-40 (AFL)
Viscosity at 40 deg C: 79.7 cst
Viscosity at 100 deg C: 13.7 cst
(FYI - this oil is one of the thinnest in it's SAE grade vs other 5W-40 oils available)
10W-30 (AMT)
Viscosity at 40 deg C: 62.0 cst
Viscosity at 100 deg C: 10.7 cst
As you can see, the 10W-30 is significantly thinner both cold and at ops temp. That means the oil will flow better cold and flow will improve due to the drop in viscosity as it warms up. Bottom line here...the 10W-30 is just as stable at ops temp and flows better both cold and hot. It also illustrates a point: You would think the 0W-40 is thinner cold (it is a "0W", right?). Not true...the numbers on the bottle are viscosity range dependant. In order to meet the SAE viscosity requirements for the "40" half, the overall viscosity must be thicker. This is due to every oil thinning as it gets hot...as I said, the 5W-40 will simply thin to a higher viscosity at 100 deg C in order to meet the SAE 40W multigrade spec of 12.50-16.29 cst.
If you want to use a bit thicker oil that is PAO based (just like Amsoil), give German Castrol 0W-30 a look. It's viscosity is 12.1 cst at 100 deg C and 71.9 cst at 40 deg C. There is plenty of info on it in this section. If you want to use the Amsoil products, I would stick with what you've been using or give 5W-30 (ASL) or Signature Series 0W-30 (SSO) a try.
