wiseco7mgt;1158533 said:
Why are wix filters good? If you going to the trouble of finding the highest quality oils for your car why not just use a K&N high peformance oil filter to match?
And what makes a K&N filter good? How about a Mobil 1 filter? Canton anyone?
My point is you need to take a look at how a filter is constructed and what media is used for the filter element. There are other considerations as well. You just can't waltz in and say "just use a K&N high performance oil filter" based on what? Your opinion? Read this:
http://www.supramania.com/forums/showthread.php?t=42763
K&N is a decent filter, but is expensive for what you get. I'll stick with my Wix filters
CyFi6;1158544 said:
I have read this numerous times, but what i don't understand is what exactly about it makes it a less superior oil compared to a "true synthetic"? Does it not have the same additives because it isn't a "true synthetic", does it not lubricate as well? I constantly hear Mobil 1 being called out for not being a true synthetic, but what are the obvious disadvantages to that, is what my question is, basically.
If you want an in depth answer, you'll have to dig it up on your own...not going to write a 5 page essay here
Basically, synthetic base stock oil has uniform size molecules in it's make-up. Better film thickness, viscosity range, and flow characteristics are a few of the benefits. Hydrocracking is a an effort to do do basically the same thing, but look at it "in reverse". Synthetic oil is "built", hydrocracked oil is "cut down" from crude oil to get similar results. The results are going to depend on how many passes and how precise the hydrocracking process is...in any case, you will still have molecules of different sizes in the base stock. It's the nature of the beast...it's up to you if you want to run the best or something less than.
What does make a difference is the additive package, especially on a hydrocracked "synthetic". This is the #1 reason I like Pennzoil Platinum...the add pack is superior. Plus the hydrocracking process Shell uses (Shell makes Pennzoil) is very good at producing the uniform molecules I talked about...better that what Exxon does.
Mobil 1 was a PAO based synthetic oil...Exxon switched to a hydrocracked base several years ago (without telling anyone) in an effort to cut cost. Keep in mind this is a corporation that has posted the highest profit on the planet of any corporation. By switching to a cheaper base stock, they helped increase their profit margin. So if you want to support a lying, greedy, price gouging organization run by people with no morals or integrity, keep buying Exxon Mobil products...I'm sure the Exxon executives will play a hole of golf just for you
