Allans White Supra
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
I had to cut my bonnet support strut in order to fit my 600x300x100mm cooler. Ive just got the top part bolted up and the hood works like it always has been. What way are you going to run your lower ic pipe? Are you getting a forward facing intake?
Allan_MA70
1,055
Melbourne, Australia
I'm probably going to run it out of the turbo across infront of the rack thru the LHS splash panel and into the cooler, and use the stock cold side, i'm going 2.5 inch on the pipes so hopefully not tooo lagy!
Allan_MA70
1,055
if you had not guessed it from Ians above post... the block.. she cracked! same place as all Ians pre-new block trials!
from the steam hole to the head bolts!
any one else here ever crack tested a 7m block????
mickyg
7MGE MX-73
Sep 15, 2005
406
Melbourne AU
Are you serious? That's crazy! Can you get pics cause I'd like to see where these start. And there's the morbid curiousity that makes me want to check my own block - just to be sure!
mickyg
7MGE MX-73
Sep 15, 2005
406
Melbourne AU
So here then (I didn't know those were steam holes and just thought they were extra cooling jacket holes):
Allan_MA70
1,055
Well after talking to the guys at crankies and Ian (crankies and cranky even ;) ) the cracks are REALLY fine and likely would stop at the bottom of the bolt hole... so all systems go again all be it with some mild loctite to seal the thread on the studs!
