fixitman04;1465531 said:
rob have you priced bend-tech software? upwards of $600!
Bend tech pro is around $250
leecheater;1465336 said:
Rob,
I fully understand the savings aspect, however, welding chromoly requires tig welder and you have to get it inspected. Plus, most tig welders don't have a lot of experience with it. We don't have the welder or the bender.Dan
leecheater;1463249 said:
. A full cage is $2400. He requires $500 down to get on the list.
You dont have one, .............yet. Is what I was getting at. If your going to spend $2400 for each roll cage, 2 of them, (your and Sean's) that is almost $5k!!
Buy a quality bender for $2100, + bend tech pro for $250, and your at $2350 ish.
Add in what ever tuning you want to use, and I bet you spend less then $3k for 2 cages. Do the math and that is almost a $2k in savings PLUS you have the tools or you could re sell the bender and make your $$$$ back.
I have a local guy that can weld anything for $20-25 a hour
Also there is probably some sort of "roll cage college" that one could go to if they wanted to for a couple hundo's. That is if they wanted to learn how to.
Also it doesn't matter what you make your cage out of it, ALL of it has to be inspected before every race, (tech inspection), after it is certified.
But as always it is up to you and it is your $$$$ to spend how you want.
Just my 2 cents. :biglaugh:
