Gixx
ok
I am seeing some odd things. When the problem comes in, the knock voltage goes up to 1v. At that time I see the ignition timeing go to -17 degree adtc and I can see the throttle being held at 100. This indicates that the AEM is detecting knock and pulling some major major timing at that point. Yes I know you have knock control turned off but the datalog shows otherwise.
Unfortuantly you recorded engine speed but not engine RPM.
What wideband are you using?
Ok for the fuel injection. You need to switch from the Denso that you have in the AEM over to either the Fuel injector Clinic 880 cc/min injectors OR use the RC 1000cc/min injector for the battery offset.
Ignition
Dwell v Battery setup at 100% throughout the entire thing. that is correct. Figured out the weirdness that is AEM.
The Coil Dwell factor is set to 10 right now in your CAL. 10 x 100 = 1000 microseconds or 1 milli second. You need to increase your factor to 23. leave the dwell v RPM and Dwell v Bat at 1000 across. That should net you the 2.3 ms that the coil needs. Seeing as you are at WOT at that level. What gaps re you plugs at?
Last thought.
Load up the DEFAULT MA70 calibration file(1130_Stock MAF). Load it up to the AEM. Power the AEM off and on. Once it comes back on, load your CAL file back on to the AEM EMS and power cycle again. Do the run again (dyno or road).
