Advantage/Disadvantages of moving the radiator to the back?
Status
Not open for further replies.
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
I've been wanting to do this to the supra ever since I saw the Dent Sport 240 (S13?) in a magazine.
Heres what I can think of:
Advantages:
-Longer coolant lines=More coolant=More cooling capacity
-Weight reduction
-Cool factor
Disadvantages:
-Poor airflow?
-Losing weight over the rear tires.
Help me add to the list so I can make my decision.
ToyoHabu
261
Huntsville, Alabama, United States
Disadvantages -
no ram air must use large expensive electric fans all the time
more weight - extra pluming, coolant
more complexity
more failure points
much more difficult getting air out
advantages -
move weight around
radiator less vulnerable to damage thats why you see off road race vehicles using it.
those are the primary reasons to do it despite the disavantages with the second usually the only real reason
americanjebus
Mr. Evergreen
wa.
Its a reasonable move w/ the dentsport 240 because of the way it was built. It uses ram air because of the ductwork made specifically for that setup and has no big airflow restrictions behind it. Look at it its just open.
To make this practical on a MKIII would be REALLY hard. Weight distribution would be a plus but the complexity and work needed vs the gains is just NOT worth it. To achieve the effect that the 240 got you would have to chop out the rear end to provide an exit for the air you somehow got to flow over the radiator. If you had a targa maybe make a duct to push air behind into the hatch where the radiator is mounted w/ no glass in the hatch?
it's a smart idea on a turbo car as you don't have to layer the heat exchangers (radiators and intercoolers)
more room for the intercooler
not to mention being albe to move weight to the back, which is a good thing when you go far major weight reduction as you can chop a lot off the back and not nearly as much off the front.
The performance of that 240 speaks volumes about what some out of the box thinking will get you. But you'd still be cutting up a Supra...
They didn't start with a clean 240 by any means, so if you have a bad Supra shell, why not?
forgot to also add that race cars usually have them in the front because of the class rules
but look at GT or F1 cars, mid mounted engines with the radiators on the side so they can have a low frontal area
speed
Gone. Email me.
May 27, 2006
1,045
not here
www.timduganphotography.com
This is true, but since the 240's frontal area hasn't changed, that point is null and void. And when I was doing my racing, I never heard of rules stating that it must be in front. It just makes sense, thats why its there. V mounts are the ideal mounting, as the air coming off the radiator will be hot, and passing that hot air over the top of the car will aid in reducing drag (hot air rises- duh), as well as keeping the engine bay cool.
when we built the two nobles, both ahve front mounted radiators. Why? cause it cools the best.
edit: oh, and any weight transfer issues are negligable since you're adding more volume of fluid, you're raising the wet weight.
not when you need the weight in one place and not the other...
overall he's moved more weight to the back...
not saying I'd do it, but that car is seriously badass performance wise, I gotta dig up the issue to see when they did underhood (I think they did something weird that warranted moving it to the back, but I forgot...)
Yellow 13
Lurker
Apr 4, 2006
2,308
Its seeming like a good idea to me. I'm thinking I wont cut the whole back off like they did but instead just cut out the rear floor pan and weld in a piece of sheet metal with a hole large enough for a radiator.
I have a hard top so I'll either run the ducting for it from some slots in the roof, from the metal behind the door windows, or the rear-side windows.
If I dont go through with it Ill probally try for a V-mount setup like Joe said.
speed
Gone. Email me.
May 27, 2006
1,045
not here
Woot, looks like lambarossa has a fan. Looking forward to pictures
Status
