ac question
figgie
Twin Cities, Minnesot-ah
tbcmorris;1119636 said:
Wrong. Cold ac is still warmer then the out side.
And wrong. I said it doent block it that much. Obviously it impedes air to a certain extent. If your ac is not on your condensor is not blocking air flow that much.if it did then you would over heat.
Actually provide facts rather than "wrong" which you are AGAIN.
The A/C air (when the compressor is engaged) is warmer than outside temprature? Really? Do you even have one clue as to how the A/C system works? Perhaps you live in the North or South pole but for the rest of the world.
I will help your incomplete (for lack of using choice words) sentence.
Cold A/C is warmer than outside temprature ONLY if the outside temprature is less than 38-42 degrees farenheight or your A/C system is broken or lacking in refridgerant.
as for your 2nd sentence. I suggest you go back to your HVAC school.
The condensor impedes air flow as there is a pressure delta between the incoming air, the air right after the condensor and air after the radiator. that pressure delta means only one thing, it is impeding air flow. And you said not by much. So what is "not by" much? 20 in/Hg? 2 in/Hg? Need numbers as "not much" just does not fly here.
You best brush up on your physics if you are going to be spouting off nonesense as you have done so far.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Dude you are in waaaaay over your head. Stop before this gets more embarrasing for you. :3d_frown:
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
I was clearly refering to a cars abilty to defosrt in winter. In which because you have no warm coolant going to your heater your car is a nice guy to you and attempts to clear your window with ac. When the ac will be colder. If you ditch ac good luck defrosting in winter.
And second again. The airflow is NOT block THAT MUCH.
figgie
Seriously, stop while you are neck deep before you drown yourself.
You are not to familiar with Toyota Supra's A/C system and in particular what the A/C amplifier does huh?
AC dehumidfies the air inside the car = no fog.
warm moist air inside = fog on the inside of the windows due to the temp outside being cooler.
Mk3's are prone to this as they leak so inside the car is usually damp.
