tbcmorris;1119636 said:Wrong. Cold ac is still warmer then the out side.
And wrong. I said it doent block it that much. Obviously it impedes air to a certain extent. If your ac is not on your condensor is not blocking air flow that much.if it did then you would over heat.
Actually provide facts rather than "wrong" which you are AGAIN.
The A/C air (when the compressor is engaged) is warmer than outside temprature? Really? Do you even have one clue as to how the A/C system works? Perhaps you live in the North or South pole but for the rest of the world.
I will help your incomplete (for lack of using choice words) sentence.
Cold A/C is warmer than outside temprature ONLY if the outside temprature is less than 38-42 degrees farenheight or your A/C system is broken or lacking in refridgerant.
as for your 2nd sentence. I suggest you go back to your HVAC school.
The condensor impedes air flow as there is a pressure delta between the incoming air, the air right after the condensor and air after the radiator. that pressure delta means only one thing, it is impeding air flow. And you said not by much. So what is "not by" much? 20 in/Hg? 2 in/Hg? Need numbers as "not much" just does not fly here.
You best brush up on your physics if you are going to be spouting off nonesense as you have done so far.
