LOL...the only verdict that's in is if you choose to use the stock rods on a high HP motor is the prep required.
As usual, the devil is in the details
If you choose to go cheap and use the stock rods on your expensive, built, 600 HP motor, you can:
- IF you have the rods thoroughly inspected for structural integrity
- IF you have the rods re-sized
- IF you use ARP bolts
- And realize you are near the design limits for the rods...there will be little pad. The motor will not tolerate significant tuning errors
If you use new billet rods:
- They are already sized
- They come with ARP quality bolts
- They are factory inspected
- Will give you a 30% + margin concerning strength
The bottom line is you can't take your stock rods and just slap them in a motor that you're going to push in the 550-600 HP + range.
Prep is critical
Prep is critical
