tookwik4u89 said:How the heck did I miss this thread, it's one of my favorite subjects:nono:
Slacker!
toyo4life said:Does any body else have this problem?
My trans takes forever to shift out of 1st or 2nd when the trans is cold. And when it does its a hard shift. once its been driven like 5-10 minutes it shifts fine.
Should I have the trans flushed? It only has 77,000 on it.
tookwik4u89 said:I flushed out a spare stock oil cooler, and I run it inline with the factory/radiator cooler. Where it sits in my bumper, it's right out in open air. I built the trans about 4 years ago, and the fluid still looks new. Granted, I only drive it 6 months out of the year.... But it has seen at least 30-40 drag passes in the summer. I have basically the same setup as jdub.
I dont have a picture of the setup, and you can't really see it here but its right in the hole outside the pass. fog light. When I had the stock bumper, I had it right in the open air in the front. I put the cooler downstream from the radiator.3p141592654 said:Tk, do you have a picture of your setup? I have an extra stock oil cooler that I was going to rig like you have done. My original plan was to piggy back it on the existing oil cooler.
LOL, read my last post again3p141592654 said:Thanks. Did you plumb it into the stock rad cooler before or after your external cooler?
jdub said:Yep...you have a tranny code:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=AT&Page=13
An auto (equal cars) will usually do better in the 1/4 mile by keeping constant boost. Assuming the tranny is in good shape. Like I said, my auto tranny was built by IPT w/ a 3000 rpm stall. I launch by stepping hard on the brake and run the rpm up to stall speed. Instant boost off the line...best 1/4 mile I've done is 11.87 (my motor is not stock)![]()
