A340E and HP questions!
Isphius
Supra-less :(
May 30, 2006
359
long branch
Ok, Ive got my 88 supra, getting a new HG, arp studs, 3 inch exhaust, etc. My main question is, how much will the a340e hold up to, and more importantly, how long? I know the main thing that kills an auto trans is heat and clogged TCs. So I plan on replacing the torque converter, And installing an inline filter and giant B&M trans cooler near the radiator, so it will stay cool but never below operating temperature. Im thinking also keeping OD locked out most of the time will help things, Because a trans going into OD and out all the time generates clutch band heat. Any suggestions here? Also, what rear gear did the stock 88 turbo targa auto come with? It has the sports package and LSD, So does anyone have an idea?
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
based on my 1/4 mile ET/MPH im running in the ballpark of 290whp, i have a bone stock 170-XXX mile tranny with only the accumulators shimmed and it runs fine. i also have a small cooler in front of the radiator.
do the accumulator shimming, get a big cooler and a thermostat and you should be good for low 13's. if you get a bigger turbo get a 3kstall for like 450, and rebuild it with IPT's blue friction rebuild kit. from what i hear that makes it last alot longer.
suprarich
Guest
Nov 9, 2005
2,187
ohio
300 hp is a safe number for the stock tranny with cooling help. Heat is not the biggest killer, overpowering your clamping force on the cluch pack, causing them to slip, is the big killer when going over 350 hp on a stock tranny.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
you can never have too much clamping force on the clutchpacks. if anything the more the better. heat in the tranny fluid is the biggest killer aside from enough power to break parts or force the clutches to slip.
tranny fluid at 180 degrees F will last about 2-4 times longer then the same fluid in the same tranny at 212 degrees F, or at least thats waht ive herd.
since tranny fluid is what makes the clutches have alot of friction to eachother you want them bieng bathed in good contition proper temprature fluid.
clamping force is what hold the clutches together. not force them to slip.
jamesdem1123
98
Palm Harbor
yea i dont what kind of power they can hold, all i know is that my a340 was stock, clamped onto a gte with an upgraded turbo, complete 3 inch exhaust and 10 pounds of boost and now 2nd gear doesnt hold on at all, for me to go 50mph requires the engine to stay near 3000 rpms, with OD on!
plaaya69
87T Supra
Nov 18, 2006
947
7
Lake County, IL
^ That sucks but what engine was your a340 originally from? a 7mge or a 7mgte. I just rebuilt mine for my 87 Turbo Supra at a aamco transmission place about 5 months ago and I drove it home and it shifted very nice after that but I only put about 50miles on it so far because I am rebuilding my JDM turbo motor over the winter.
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
320rwhp/362rwtq, non rebuilt, tons of miles on it, shifts smoothly, been like this for about a year....with tons of abuse (Not BASHING it, just taking advantage of it) ;)
Reason it's been holding up this long is because I got a Tranny cooler RIGHT away when putting this tranny in.
Heat KILLS the transmission.
Anywho, I as well, will be going to IPT to rebuild my A340E. :)....
Because I don't think it will withstand the amounts of power I'll be throwing at it soon. :(
Jeff
jdub
Feb 10, 2006
10,730
Valley of the Sun
Yep! I as well have a tranny cooler with a Spal fan on it running full time.
Also installed a tranny fluid filter ;)
suprarich
Guest
Nov 9, 2005
2,187
ohio
I did not say that too much clamping force is the killer. I said over powering your clamping force is. That means too much power from the motor overcoming the holding capacity of the clutch pack (clamp force). :3d_frown:
What tranny cooler do you guys reccommend? I dont think Vonda's is going to last long with that new turbo installed. It has just been rebuilt though, but not with an upgraded kit. Her car has my same setup, and I mad 406rwhp on my car, but it was a fivespeed. I'm not real sure her torque converter can handle it.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
whoops. it looked like by saying "overpowering your clamping force" you ment, having too much clamping force. oh well.
jdub
Feb 10, 2006
10,730
Valley of the Sun
3000 rpm stall...the Raybestos clutch plates are a significant upgrade. I had the full mod done to the tranny...converter, friction, valve body, etc. It's holding up very well...barks the tires when it hits 2nd ;)
Isphius
Supra-less :(
May 30, 2006
359
long branch
Whoa, tons of info. That was fast! lol. But yeah, whatever it comes down too, letting the trans get to hot is the easiest way to kill it (besides making more power than the physical parts can actually hold...). Also, like you were saying, clamping force. Older/worn/not taken care of trans fluid clogs up the torque converter, which means the clutch actuators get no pressure, which means they slip, and cause heat, which makes the fluid break down and let everything fall apart. I basically want to eliminate it at the source, the fluid getting hot and the TC getting clogged. Another thing thou, Does the accumulator mod increase the line pressure in the trans? Is that how it makes it shift harder? Or is it just letting the gears engage faster? If so, This would def help the trans last. The harder it shifts, the less its slipping, the less it heats up. Thanks for all the info tho!
toyo4life
238
Manchester NJ
Does any body else have this problem?
My trans takes forever to shift out of 1st or 2nd when the trans is cold. And when it does its a hard shift. once its been driven like 5-10 minutes it shifts fine.
Should I have the trans flushed? It only has 77,000 on it.
