A norwegian single-turbo MKIII 2JZ build
90Supra-gte
Excited
Feb 9, 2007
Norway
hi!
Now I'm finally starting my 2JZ-GTE swap! I have been shopping parts for a few months now and still have some buying to do before i'm finished. The 2JZ will be comming on Tuesday. The car is a Red 90 Supra Turbo.
Here is what I have already bought (From driftmotion, MVP and EBay):
2JZ-GTE Engine/ECU/Harness
1JZ Intercooler
1JZ Oil Pressure Sender Adapter
T4 turbo exhaust manifold
2JZ Engine Swap Brackets late 89-92 MK3
2JZ water pump
ARP Rod Bolt Set 1JZ/2JZ
NGK Iridium IX spark plugs
Gates Silicone Radiator Hose Kit Blue
Gates Blue Timing Belt
REAR OIL PAN 2JZ-GTE
ATI Super Dampner Crank Pulley
GReddy Oilfilter Relocation kit
Serpentine Belt No A/C
NPR Piston Rings 2JZ-GTE
Full Gasket Set 2JZ-GTE
FIPG Black "Form In Place Gasket"
1JZ Fuel Dampener Bypass Hose
Fuel Rail 2JZ-GTE
Dual Walbro Fuel Pump
ARP 1JZ Flywheel Bolts
1JZ/2JZ Bell Housing Bolt Set
Hardened Urethane Shifter Bushing For R154
Clutch Hose for R154
Clutch Slave Cylinder R154
AEM F/IC Piggyback EMS
And this is what I have left from Drftmotion:
1JZ Lightweight Flywheel 11.5lb for R154
1jz/2jz mk3 AFPR kit for -8 rail
1JZ/2JZ to R154 Bell Housing
Driftmotion T-66 Turbo
Stage 4 clutch kit 600ft/lbs!!!
AEM UEGO
ARP Main Stud Kit 1JZ/2JZ
ARP Head Stud Kit 1JZ/2JZ
Apexi Power Intake 86-92 Supra
2JZ throttle cable
Walbro Fuel Pump For 84-92 Supra
1JZ/2JZ Power Steering Hose
HKS Style Wastegate
Blitz Type 1 Radiator Cap
JZ Pulley Kit
7M-GTE oil presure sender
Clutch Master Cylinder MK3 Supra
1JZ/2JZ Thermostat
ACL 1JZ/2JZ Race Bearing Set
1JZ Front/Rear Main Seals
Marlin Crawler R154 Bearing Retainer
Marlin Crawler R154 Thrust Washer
Motor Mount For 1JZ/2JZ/7M x2
I will post pic tomorrow :)
mrsuprafreak
Where does it end?
Aug 14, 2005
267
Orlando
90Supra-gte;1152518 said:
hi!
1JZ Intercooler
2JZ water pump
Fuel Rail 2JZ-GTE
Driftmotion T-66 Turbo T4, 650 hp!
AEM UEGO
2JZ throttle cable
HKS Style Wastegate
JZ Pulley Kit
1JZ/2JZ Thermostat
That's awesome that you are doing it right by getting almost everything you need to complete the project. Keep us posted with pics and problems and etc...
mobes
Supras are never 'done'
Bozeman, MT
This ought to be good, you Scandinavians don't tend to mess around.
I'll be looking forward to seeing the end product :)
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
Looking like a great list there, only thing I don't think is completely covered is fuel. Is your 2j coming with 550cc or 440cc injectors? You're going to be able to max out the 550cc injectors and one walbro pump with a 2j and a 66mm turbo. I'm doing it now on a 1j with a 61mm on pump gas :)
90Supra-gte
Excited
Feb 9, 2007
Norway
Its an Aristo engine, so 440's i guess. I have not yet desided which injectors to go with. I have a "denso" style fuel rail so need that kind of injectors in 680 or 720. What will be best for my setup? :1zhelp: Aiming for 500 whp.
mobes
Bozeman, MT
Why only 500 with a 66mm turbo? You seem pretty excited about the fact that it's 650hp capable, so why not take advantage of that?
You can squeeze 500 whp out of 550's but you'll be right on the edge. However, your turbo has more potential than that, I say up the fuel to match. I would say 720's and of course you'll need a pump that can flow enough fuel.
Here's a good thread on pump options for that horsepower range:
http://www.supramania.com/forums/showthread.php?t=71619
90Supra-gte
Excited
Feb 9, 2007
Norway
Hehe, the 650 hp! thing is from driftmotion. I just copied the whole line.. :p So the Bosch 044 intank pump would do better for 5-600 whp than two walbro pumps?
90Supra-gte
Excited
Feb 9, 2007
Norway
I finally recieved my engine today. Looks pretty good. :) And I ordred some more parts yesterday. Here is the list;
AEM UEGO
2JZ throttle cable
Tial 46mm Race Wastegate
JZ Pulley Kit
Clutch Master Cylinder MK3 Supra 86-90
1JZ/2JZ Thermostat
I hope I'll get to get some work done tomorrow. Cant wait to get started. :evil2:
Pictures!! :D
90Supra-gte
Excited
Feb 9, 2007
Norway
More pictures ;)
90Supra-gte
Excited
Feb 9, 2007
Norway
Thanks guys! :)
Got some work done this weekend. Now I'm just awaiting parts from Driftmotion before I can put everything back together :D
90Supra-gte
Excited
Feb 9, 2007
Norway
Ordred some more parts from MVP :icon_bigg
Powerhouse Racing Oil Pump for 1993-98 Supra
Blue Hose Techniques Kit For Toyota Supra 1993-98 Twin Turbo
Clear Titan Cam Gear for 1993-98 Supra x2
Brian Crower Camshafts 264
ATI Lexan Spark Plug Cover
TRD Oil Cap for 1993-98 Supra
Topaz
8
Eidsvoll Norway
Hei, hallo and hi there
A pleasant surprise seeing you here.
And by the way...I might be interested in your 440`s if you want to sell them.
If so, you can pm`me over at TS-OGN.
90Supra-gte
Excited
Feb 9, 2007
Norway
Its been a long time since I updated this. I have done some work on the engine. Do you guys think my wastegate setup will work out okay in the engine compartment? I really hope so.. :icon_razz
90Supra-gte
Excited
Feb 9, 2007
Norway
More pics from the assembly and when I changed taillights :icon_bigg
AbsoluteSpeed
735
Edmonton AB
I like how you work, get everything done all at once, I would do the same if funds allowed it.
Nope, you had better ship the motor over to me I'll take care of it :evil2:
Kidding. Subscribed!
