This has been pissing me off and I can't figure out whats going on. A few days ago I decided to make an intake pipe because the stock accordian was all cracked-out.(I got pics if anyone cares to see) After making/installing this intake, the a/f ratios have been high,low, and everywhere in-between.
It goes like this: Start the car(cold), car idles ~600rpm (lower than usual when cold) and a/f r's go from the 14's to high 16's and 17's and then to this, - - -:aigo: . So I'm like WTF! Fuel press is about 25psi w/vac. I try turning up fuel pressure to lower the a/f r's, ~35psi gets it to high 14's low 15's under idle. I know this isn't right and shouldn't have to raise fuel pressure like this. So anyway, I drive the car and they're staying steady in the mid 15's, it'll drop under acceleration, but goes back to the 15's as vehicle speeds evens out to cruise.
I drove the car to the store like this and after getting back in, I fire it up and a/f r's are about the same, high 15's, but then go pig rich in the 12's at idle and at cruise.
At the gas station I had to turn down fuel pressure to get it to idle at 14.7ish.
Anyone have any ideas? Can this intake be f-ing up my afm? is my w/b f-ed? o2 sensor? No codes BTW. Any help would be greatly appreciated.
