Poodles said:*sigh*
the issue is the system throws too much heat into the brake fluid... a BBK has more mass in the rotor and keeps the heat out of the brake fluid
of course there are things people make called brake ducts and if you are overheating dot 4 brake fluid on the street then maybe its time for some actual brake fluid like super blue etc
i just dont see how you can overheat the stock brakes on the street i never had fade issues at the track if you want me to ill put some thermal paint on the caliper to check fluid temps if you dont belive me i really dont even think when i start in the race groups that the 40 minute races will warrant a BBK for me because ducting will make a world of difference as far as temps
all im saying is 20+ minutes lapping on a track threshold brakeing did not result in fade BUT i have ceramic pads in the front which dust alot and lost a ton of material over the course of the weekend so maybe metalics will overheat
