Well here is sort of an update. After re-degreed in the 272 cams I am able to get the timing set to 10 degrees, I think. I still have code 41 and some thing is up with my TPS. When I jumper the diagnosis box on a cold engine my idle sits at 1500 rpms and the timing light is showing it at 10 degrees. After a min. or so of run time the Idle is very erratic, jumping from 1000 to 2000 rpms. Once I rev. the engine the idle jumps down to 700 or so and stays there for 5 sec. then goes back up to the 1000-2000rpm thing. So there is something still fubared up with something.
The electrical box has been turned and mounted 90 degrees from OEM spot for clearance on the FFIM. I Still need to find a spot I like my battery in the hatch spot area. My CD changer is on the passenger side where it “should” go. I want to find a spot that hides it well and doesn’t stick out like a sore thumb. Speaking of the CD changer it all of a sudden started working!!!! When I installed it with my Pioneer D2 my head unit didn’t recognize it so I could chose it to playing anything. Now last night I went to turn on the radio in the car and “bam” there is was ready to rock and roll. I don’t know why it started to work but whoo, it’s working.
My puke can (radiator overflow tank) that I ordered Is here but I don’t like it. You are able to see is next to the intercooler from the front of the car. So it’s back to the OEM one and make it work somehow. Maybe some 200 mph zip-ties will do the trick.
The only problem I’m in on the GB for the Regulus nose piece and I am worried that the puke can could be seen through it once that is installed. But I will worry about that when that time comes.
I also need to spend some time on the coolant neck area wires. Right now they are hooked up but it looks like a rats nest, so I need to straighten them up and get some wire loom around them.
Last I need to find a place for the A/C twin fans. My intercooler piping is now in that place and don’t know where to install them at. Also I am trying to find a broken fan shroud since I only need the side with the “main” cooling fan, I don’t want to buy a new one and cut it up.
Or I might just order a universal “chrome” one but again I don’t like the way the chrome ones look, I like the OEM look to cars.
Other then this Idle problem that car is ready for a rip.
