I was recently in an instant message with Ethan (92TealSupra), and he mentioned that you could use an 89 harness in a 92. I told him that the big square plug (he called it B1) did not match, and he said that the wiring was the same, only the plug was different. All I would need to do is cut off the connectors, and connect the wires. I then had to get back to work, and couldn't talk about any other differences.
Is it just that simple? Is there a place I can get the correct plug to swap onto my harness? Toyota, I guess???? And, is it called the "B1" plug? Is there anything else that I should be aware of?
