88 7mge issues HELP!!!!!
bioskyline
1,236
powell river bc
Bigin1987;1732965 said:
Being there's a banjo bolt on the cold start injection port how to you test the fuel pressure with the type of guage I have? Or is there a different guage to use?
on the rail, you should be able to screw the tester into the port once its off. you dont test thru the csi hose. the banjo is right beside the tb, shouldnt be to hard to get to
Devin LeBlanc
1,830
Las Vegas NV.
My test gauge has a banjo bolt with a quick connect fitting on the top of it to connect the FP gauge too. So when its hooked up the CSI is still hooked up. Its a kit with about 100 different sizes/fittings. Its just a banjo with a fitting on top. They are all different.
8,900
Poodles;1732900 said:
They're also a huge waste of money...
That they are. The last 7MGE I saw run rich, black smoke and all, it had the airflow meter tampered with. The owner loosened the spring on the door because he read it on the internet.
Bigin1987
Midwest missouri
Ok well the update on the car is that once I set the fuel pressure to 40 it acted like it wasn't getting gas. It would stutter and wouldn't go over 1200rpm. The reason I set it to 40 was because once you start driving and the gas is pumping through it drops a hair. But like I said it ws acting like it wasn't getting gas so I set it to 45 and it ran fine just a little rich.
Do you all think it would be the injectors or maybe the throttle position sensor or what???
Please help me on this cause I'm running out of things to check. All help is very much appreciated.
8,900
No. I really think they are a waste of money, in a certain way. Although I was thinking of many spark plug ads that claim power gains. BS.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Oh well, in that case you're 100% correct. Except for oil there's no greater scam perpetrated upon the automotive public than ignition components. I was referring to other characteristics of precious metal electrodes that are worth the expense.
Bigin1987
Midwest missouri
Well like I said I checked dizzy, timing, tps, coil, I have all new plugs wires dizzy cap and rotor bug and the wires have the right resistance and all plugs are gapped correctly. All vacuums are legit brand new 2.5 inch exhaust with cat gutted out. The only ohm resistance I haven't checked would be on the injectors. And I haven't checked the fuel pump but if it's running rich than I don't think it would be that.
So what else could it be???
Bigin1987
Midwest missouri
I've also checked the amf and it checks out.
But please guys let me know what you think it might be so I can check it if I haven't already cause obviously I'm a noob to supras and Toyota in general.
rodama5anthony
430
Bay Area, CA
just cus the resistance reads okay doesnt mean there isnt something wrong with it replace the afm and see were that leads you or if you have a buddy with a supra borrow his
Bigin1987
Midwest missouri
I don't know anyone that has a supra around here I have the only one that's on the road within 100 miles that I know of. And I don't want to just start buying parts and that not be the problem.
Has anyone had these problems before or what could it be???
I just don't want to spend $1000 in parts and not fix the problem.
8,900
How about $500? I doubt you live that far from civilization.
Bigin1987
Midwest missouri
I know it is. and the reason for me repeating myself is because im trying to find out whats wrong with this car. But noone is helping me with it. Everything that everyone keeps telling me to check i already have 2 or 3 times and the problem still persists. So im hyoping someone will help me so i can get this car running right and be worry free.......
