'87 Drag Car 7M awesomeness
Albert
May 13, 2009
1,710
Tempe, AZ
NegativeGeForce;1989118 said:
i got a response from ati about the custom trigger shell. cost is $450 and potentially a 5 month wait. O_O
Yeah he got a $600-$1200 cost with a 2 month wait.
Weird
stevenr816
932
Phoenix,AZ
Update: waiting for fittings and poly stuff so I can swap frames. Been working on the body.
Wtf on ati, it says right on their site it's $100 for 12 magnets? It's probably the AEM style?
Florida
Yeah I already have the ati damper for the 7M so I was just asking about a custom shell for it. That does come out all together for about $900....pretty crazy for a damper.
So since i am crazy. I think im gonna order the shell. What do you guys think is the best configuration for the shell? Magnets (and how many) or the AEM style? The ATI guy says it doesnt matter...so long as the ecu can work with it.
Albert
May 13, 2009
1,710
Tempe, AZ
Well hopefully sometime this week now that Steven has cash, we can get that ordered... Only real big thing that would prevent it from starting, I guess we can still use the old trigger setup.. But not liking how it's so flimsy.
That and a trip to Proefi to finish getting some shit. If that gets all ordered I'm sure this thing will start and drive in April
Albert
May 13, 2009
1,710
Tempe, AZ
stevenr816;1989126 said:
Not really. The ati replacement dampers only support 500-600hp they said cause its the smallest damper they make.
Which is weird cause the stock dampers I've seen go to 900hp.
What is Duane on? On know he doesn't have a shell, he is on a trigger wheel setup but still. Tony? Milbrum?
Just seems odd that and aftermarket damper even tho it is small can't handle 700hp
Florida
Thats true I forgot about that. If Im gonna throw that much money at a damper I might as well go big. I think im gonna end up having to order the same damper as you. Maybe if they see two orders they could make it faster?
Florida
If I recall...off the shelf damper is good for about 600hp sustained and 900hp drag racing they say. More power you make the more often it needs to be rebuilt before it goes bad. So a larger damper would last much longer.
Florida
Heres duanes damper. Looks like the off the shelf one with a trigger wheel. If it's bigger then its not by much.
Albert
May 13, 2009
1,710
Tempe, AZ
Yeah I don't like that setup, just like I don't like a trigger wheel over the cam gear.
Trying to do everything hides and mag pickup instead.
Florida
Let me know what you guys end up with. Might be better off ordering 2 identical dampers at the same time.
Albert
May 13, 2009
1,710
Tempe, AZ
Yeah ball is in Stevens court, depends what he wants to do. Maybe call ati and ask if it will be any cheaper to build 2
stevenr816
932
Phoenix,AZ
You couldn't tell if the damper was bigger or not unless you referenced it to the radius of the timing cover.
I'll put in the work order for 2. And ask them if it would change the price at all. It's just to get an estimate.
Florida
Yeah, what size were you thinking of going with?
Guess we will need longer accessory belts for it. I have a nice set of gates racing accessory belts already
