As some would be aware through other posts, my engine with a fresh head gasket and ARP head studs had a big overheat due to a popped welch plug.
Well, it's been two weeks, and the residual symptoms appear to be none!
That's right, so far, th eengine that got so hot it MELTED the plug leads to the plugs is running like a top, with no coolant loss, no overpressurising of coolant system, great oil pressure etc.
So, I think it shows that the stock head torque SUCKS and that decent head studs and a good gasket will tolerate a torrent of abuse.
Not that I expect I haven't damaged the engine in some way, it will probably only go to 200k kms now, instead of 300k, but it is a solid display of good engineering.
I persoanlly think the oil squirters and oil cooler helped save the day. Oh, and I am pretty sure the ECU just dumps fuel into teh engine when things get too hot, all the plugs were very dark grey and didn't realy look overheated at al.
Regards, Andrew.
Regards, Andrew.
