7mgte vs hks t04z rx7
al lewis
100
dominica
hey guys last week friday i got a beating by 4 car lenghts from my brother in his Mazda RX7 which is running a HKS T04Z turbo Kit and 18psi. I need to beat this car please advise how this can be done all races will be done on a staight abandoned road with proper safety measures. Please also advise if you would like me to list my mods.:: angry ::
te72
Classifieds Moderator
6,607
4
WHYoming
You're not listing any info on either car other than the turbo and pressure on the Rx7. Is it still rotary powered? Anyhow, considering that he weighs ~2/3 of what your car weighs, you've got an uphill battle ahead of you. Unless you were to change out for some more aggressive gearing toward the acceleration side of things, you're gonna need a good deal more power than he has...
al lewis
100
dominica
Mods are as follows guys Full HKS HI Power Exhaust System, Lipp 3" Turbo Elbow, 3" Test Pipe, MKIV Twin Turbo Supra Fuel Pump, Aermotive Fuel Pressure Regulator, Upgraded 57trim CT26 Turbo, Greddy Airinx Air Filter, Greddy Type RZ BOV, HKS PFC -FCON ECU, HKS FCD, HKS 3000 Intake Pipe, Spearco Front Mount Intercooler with 2.5" Piping, HKS Metal Headgasket, ARP Bolts & Studs, Fidanza Cam Gears, Magnecor Lead Wires Running 14.5psi. These are just engine mods. The RX7 on the other Hand has a Street Ported Engine, HKS TO4Z Turbo Kit 1300cc Secondary Injectors 850cc primaries running an Apexi Power FC Standalone ECU Full Exhaust System and other supporting mods and 18psi.:: angry ::
al lewis
100
dominica
i'm running 14.5psi sean. 100 Shot ummmmmmm do i need all that? would the engine be able to take that? i do have a cooling mist meth kit which is not installed yet what do you think?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
4 car lengths is a LOT. To beat that, you'll need to shave off *more* than 4 car lengths. A 50 shot isn't going to cut it. Hell, a 100 shot probably wouldn't either. The danger is inside the engine - do you have a built motor to lean on? If not, you're going to need one - if you want it to last, anyway.
Personally, I'd build the engine for much higher power - forged internals, basically - upgrade the fuel system to about double what it looks like you've got there, scrap the upgraded CT and go for a bigger turbo with an external wastegate, ditch the alphabet soup electronics and move to a real standalone, upgrade the brakes, suspension, and tires, and then give it another go.
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
+1
LOL @ "ditch the alphabet soup electronics and move to a real standalone"
IJ.;1611832 said:
Can't PIT if ya can't keep up ;)
True dat,
Maybe bring a strong flash light along and blind him (temporarily) just before you start:bigun2:
Sam
Vacationtime247
74
Muncie, IN
To overcome the distance with that heavy supra is going to take a lot more HP. The RX7 is light and those rotary engines spin up to 8K rpm quick. Hope you have a low rear differential such as a 3.42 and change it out for a 4.30 LSD unit.
VT247
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
VT247
:squint:
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
VT247
Oddly, this doesn't seem to help. Randy recently swapped from... 373 to 411, as I recall, and his car got slower in the 1/4. Not sure why, but that's what happened.
al lewis
100
dominica
I am planning to forge the engine n so forth but one question since i do not live in a country where there is a Dyno would a standalone be a better move lets say the AEM EMS tuned on the street via loggs or just using a Piggy Back system lets say the MAFT Pro what would you recomend? also do you know of any shops or stores that specialize in 7MGTE's and building them to customers needs specifically in the miami florida area since it would be cheaper for shipping? or should i just do the build up myself with the help of my father who's a qualified toyota tech and use of local machine shops?
---------- Post added at 08:28 AM ---------- Previous post was at 08:25 AM ----------
also grim jack what Turbo would you recomend for domination also keep in mind we do alot of stop and go driving down here not to may mile straights
